November 22, 2026, 12:07:42 PM
Deleting Contacts
Started by Saudistu, March 06, 2013, 08:12:43 AM
Saudistu
Does anyone kow of a way in Basestation to ignore certain contacts ? The problem I a having, living so cose to MUC, is that I get anywhere between 4 and 10 contacts that are related to test signals from MUC. Usually they have registrations in the range D-BFTJ to D-BFTV, but recently also ones like D-BF10 have appeared. Can these be set to "ignore" in any way so as to keep the clutter down. thanks for any help.
Map clutter or aircraft list?
Saudistu
Hi Mike. Aircraft list, although some show on the map aswell from time to time.
Regds....Stu
Unless you want to set all hex codes to Interested and then remove that for the hex codes you don't want to see?
Basestation should have filter options.  Been on the Wish List for years.
Saudistu
Thanks Mike. I had a feeling that there was no easy solution in Basestation.
