November 22, 2026, 12:07:51 PM
Range Rings
Started by Dreamliner787, April 10, 2013, 11:52:53 PM
Dreamliner787
hello,
I would like to have range rings centered on my location. Is there a program still available to create range rings.
Tony
In which software do you want to see range rings?
Basestation has it but you can turn them on/off.
Assuming it is Basestation then you can select:
Settings | Display Settings - Display Parameters tab.
and check the box 'Centre Range Rings on Home', see attached picture...
Also if you select:
Help | Reference Manual
It will open a pdf and you can search that for 'range rings' to see what other options are available.
Cheers, Keef.
Graham Bell
With BaseStation running right click on the screen which will produce a drop down menu providing a range of options.
Regards-
G.B.
