August 24, 2026, 06:28:40 AM
Adding route to base station
Started by ke7aa2pv, May 27, 2013, 03:30:47 PM
ke7aa2pv
Hi all,
Wonder to now how to add route in basestation like in this picture of BONES AVIATION PAGE ? http://www.homepages.mcb.net/bones/SBS/Kinetic_Utilities.htm/
Uploaded with ImageShack.us
Thank's for coop
ke7aa2pv
You need to populate a route to a database field, using something like Flight Display or Active Display and then use the Scope Fields feature in Settings to show the route on the aircraft label.
ke7aa2pv
Quote from: Anmer on May 27, 2013, 07:20:30 PM
Thank's a lot, but i can't find any place in scope field for showing route ????!!!
ke7aa2pv
The first thing you have to do is use something to populate a route in a database field, such as Flight Display or Active Display.
Start there.  Explore those solutions and then you can add the database field that they populate to the Scope Field settings.
fidaeextra
I'm writing without having the windows indicated in front of me but Flight Display has an option that lets you record as much as home airport, and destination, in two fields of the database. This information is in the "popular name" and Generic name. "What I do not remember if this is for you by default or can be set in that field that are empty, you can store this information. This makes FD task automatically. after Basestation to be set in setting / Display setting / Scope fields, and indicate that shows the fields where data are housed.
ke7aa2pv
Quote from: fidaeextra on May 28, 2013, 09:29:17 PM
Ok guy's got it !!!!! :P
Thank's for help
ke7aa2pv
