September 22, 2026, 08:36:30 AM
Newbie
Started by Biggles50, June 14, 2013, 09:23:02 AM
Biggles50
Hi All
I am new to the forum and live in the UAE so hope to contribute with updated information from here.
One quick request having just reinstalled my SBS on my new PC i have for some reason lost all of my airfield outlines and approach paths etc for all the UAE fields
Also my sqb file has disappeared and despite the fact i though i had backed this up properly i obviously didnt ! :-X
I cant seem to find where these can be downloaded so i some one can point me in the right direction that would be great
Many Thanks
biggles50
Al
Al
If you have lost your SQB sbs will start a new one.
This means you will start from scratch.
How did you install Basestation on the new PC?  Did you copy files from the old one or did you use a Basestation CD file for a "fresh" install?
And do you have access to the files on the old PC?
Biggles50
Hi Anmer/Mhm
thanks for the reply
i did a fresh install form a web download
the files i saved from old PC have been corrupted when backed up
cheers
biggles50
Does that mean you have no access to any of the files from the previous PC?
Biggles50
i am afraid so !  :-[
Quote from: Biggles50 on June 15, 2013, 11:14:47 AM
OK, so you have a fresh install.
What outlines do you need?
Biggles50
yes done that now
need everything for UAE, Bali and Surabaya if you have them ?
cheers
biggles 50
#8
Hi Biggles50, and welcome  :)
If the outlines you want aren't available you can have a go at creating your own using:
http://www.acme.com/jef/outlines/
There's also a guide on outlines created by Anmer (so worth a read!) available from the downloads area of this forum.
This gives some good information about outline files and how to use the above mentioned tool.
http://radarspotting.com/forum/index.php?action=tpmod;dl=item12
Keef.
I've emailed you airport outlines for Abu Dhabi and Dubai.
Is it airport outlines you want or country borders/coastlines or anything else?
Biggles50
Hi Anmer
Thanks for the email  all received
If you have any other airport outlines for the UAE that would be great, also if you have Bali and Surabaya they would be useful for my forthcoming holiday
cheers
biggled50
Biggles50
Hi Keef
many thanks for your reply and i will look at the links you sent
cheers
biggles 50
