November 24, 2026, 11:19:48 PM
SBS1 Client - startup
Started by nikonikic37, June 19, 2013, 07:13:04 PM
nikonikic37
I would like to add sbs1c.exe to windows startup folder. Windows starts it normally but it doesn't connect until you press Start button. Is there any way that you can start it automatically?
kered
I don't have the sbs1 but you could try adding /start at the end.
In the startup folder right click on the sbs1c.exe shortcut icon and select properties
in the window that opens select shortcut tab and add   /start at the end of the line in the target window.
where it reads C:\...\sbs1c.exe , change to C:\...\sbs1c.exe /start and see if it works
It works for planeplotter so it might work with sbs1 but as i say i don't use sbs1 so i'm not sure
nikonikic37
As Anmer said there is no option in SBS1 Client that will allow automatic start up. So I've wrote my own app that will start SBS1 Client and then press Send button. Hope it will be useful to someone.
nikonikic37
If someone needs source code please contact me.
