November 22, 2026, 12:07:02 PM
Same issues as last time...
Started by Smudger98, June 21, 2013, 05:17:31 PM
Smudger98
Any ideas guys.. ???
Saudistu
Are you connected by USB or Network ? I used to get this message on my Laptop from time to time when I was using Network over USB adapters. I think it was losing packets of data from time to time. Since I switched over to using Powerline adapters I have not had this problem. That was with my old SBS-1 though. Haven't tested it on the SBS-3 with USB.
Smudger98
Hi Stu,
Normal hardwire from Lappy to SBS-1, some times i only get the error when i try and edit in BS.. run for a while then craps out..? ::)
satcom
Create a blank sqb and try running with that for a while...suspect you may have a corrupt entry in your existing sqb.
Smudger98
Thanks John.
Ill give it whizz when i get home to-day..
Smudger.
Smudger98
Ok.. tried a blank sqb and seems ok..  put back an old sqb from before any of the trouble and still get the old problem back, ??  I wondering if its some type of size issue on the DB as it was about the same size last time it went mad ?
Chris-G0WTZ
Smudge have you packed the data base?
Just a thought
I don't think it's a size issue.  As they say, mine is massive.  ;)
My guess there's bad data in the sqb file.  Finding it will be the problem and I suspect importing data is the cause.
Smudger98
Ok.. so update and latest..
On investigation, trial and testing the issue seems to have been lack of RAM memory and a flags file far too big for my PC..
On Anmers advice I upgraded the RAM and and cut down the flags file size and between the 2 now have an old lappy that goes far better than i could have ever expected..!!!  ;D (so far)
Clear so far of the errors that plagued my machine on basestation.
So as ever a big thanks for pointing me in the right direction and getting me back on the plot after remote dial sessions.
Thanks for all the help Mike,
Smudger.
Fingers crossed Smudger.
As the ewe always says.  "The more RAM the better".
Graham Bell
Hi Smudger-
How did you "cut down your flag file"?This is something that I have been meaning to do for sometime in an effort to speed up BaseStation loading
regards-
G.B.
Smudger98
#11
Hi Graham..
The slow and painful way im afraid..
By going through the flag file 1 by 1 and deleting ones i either wont or don't use,Airlines that no longer exist etc- i don't use tail flags or logos.. so they went, just thing Ill never use - duplicate types etc, I went from 9500 records down to 7100, in the event of needing one or any, Ill just re-load them.
( http://www.antonakis.co.uk/sbsflags/ )
But i went and chopped over 2000 out and it runs and loads much faster.
HTH
Smudger
Roadrunner
I have 7,200 logos in my file and have not had a problem with that error message using an SBS3 since I updated the sqlite3.dll file to the latest available (at the time) dated 16/01/2012.
Regards Mike
Smudger98
Hi Mike,
Since the major removal of not used or unwanted flags.. mine is now running fine..
I think the combo of upgrade and a good house keeping session was my answer..
Smudger.
Graham Bell
Thank you Smudger for your valued reply having checked my Flag Folder it reveals that it contains 7040 entries so compared with other mentioned folders perhaps the slow loading of the flag folder,it takes over three minutes,is more computer orientated than folder size?
Thanks again for your input.
Regards-
G.B.
