November 29, 2026, 02:45:13 AM
Hello Carl,
The log shows that modesdeco2 is trying to establish a connection to dongle, which has the device number 0. But this device 0 is already occupied or used by other program.
Or how many dongles do you have connected? To see the current situation, please run the program with the only option --device-list.
Change number to 1, for example, if this device is free.
v.20150815 ModeSDeco2 with AirSpy SDR receiver on OS X 10.10:
zachmart
Hi Sergsero.
I see you have just added distance graph and coverage pattern - thanks for that. I would like to ask you if its work in progress or if it should work because i have updated to v.20150825 but my distance graph and coverage pattern arent working.
picture: http://prntscr.com/892oj7
Command i use:
cmd /c  modesmixer2.exe --log-level %log_lvl% --metric --disable-web-log --location 14.4656:50.0468 --inConnect x.x.x.x:y --web %web_port% --silhouettes C:\SBS-resources\Files\SilhouettesLogos --db C:\SBS-resources\Files\Registration\BaseStation.sqb --log-file %log_path%\%log_filename%
%xxxx% are variables in BATCH
Thanks for answer.
Martin
Hi Martin,
Try resetting the cache in your browser by pressing F5 or ctrl+F5 while on this page.
zachmart
Quote from: sergsero on August 26, 2015, 01:35:47 PM
Hi.
Thanks for fast answer. I have reloaded the page several times with F5 and ctrl+F5. The picture was from firefox.
I have tried Chrome with same result - i have cleaned history and cache. Nothing helped.
Its not showing the data on multiple PCs (tested with 2PCs+iPad).
Martin
Hello,
This test only version of ModeSDeco2 has the additional option --disable-correction  that disables correction of damage signals. It is possible that this will be enough to solve the issue of 'ADS-B/Mode S twins':
modesdeco2_bpi_20150815_test_only.tgz https://dl.dropboxusercontent.com/u/79709204/MD2/20150828/modesdeco2_bpi_20150815_test_only.tgz
modesdeco2_windows_20150815_test_only.zip https://dl.dropboxusercontent.com/u/79709204/MD2/20150828/modesdeco2_windows_20150815_test_only.zip
Unfortunately, in my area it doesn't occur due to absent of ground-based interrogation stations. And there is no possibility to check it out.
If the above process doesn't work, I have other ways.
Please, test it.
Radio2.0
i havent the time to read all does anythink chance on ModeSDeco2 ?
thats my stats:
DF Messages Description
0 237199429 Short Air to Air ACAS
4 151800835 Surveillance (roll call) Altitude
5 111652424 Surveillance (rool call) Ident
11 379592809 All-Call Reply
16 18071071 Long Air to Air ACAS
17 252715098 Extended Squitter (ADS-B)
18 3004086 Extended Squitter / Supplementary (ADS-B)
19 16 Extended Squitter Military Application (ADS-B)
20 253865000 Comm-B Altitude
21 142044940 Comm-B Ident
vasekm
Hello,
I just tested version with --disable-correction and twins are still present.
Hello vasekm,
Thanks for your testing. I think that issue needs the special 'twins' filter and its would have to be built into program.
larsras
Also tried the test version now, and i also have the double aircrafts with the added command line parameter.
br Lars
zachmart
Is here anyone who made Coverage pattern work? Do I have a mistake somewhere or is it global bug?
Coverage pattern working fine here on both ModeSMixer2 and ModeSDeco2.
zachmart
Well... thats not cool... for me :D can you send me your execution command (without any IPs ofcause) please?
No issues with IP's for me, it's only a LAN one anyway. This is the contents of my modesmixer.bat file. I have the ModeSDeco2 one on my laptop, if you need that, please let me know.
@echo off
E:\ModeSMixer\modesmixer2.exe --inConnect 192.168.1.170:10001 --outServer sbs10001:10001 --outServer sbs30006:30006 --filter-nocountry --web 8080 --db E:\BaseStation\basestation.sqb --silhouettes E:\BaseStation\OperatorFlags --frdb "E:\PlanePlotter\log files\flightroute.sqb" --location XXX:YYY
PAUSE
exit
zachmart
thanks for command. Sadly it did not help. I have tried everything and coverage pattern still doesnt work... I dont know why...
http://prntscr.com/8azlc0
no coverage on map or in charts...
Any ideas?
