July 01, 2026, 12:22:28 PM
0 Members and 7 Guests are viewing this topic.
evangel
Hi Sergsero
all OK with my pi3 and latest modesmixer2. nice feature the beastmlat and the NOTAMs.
will be nice to see mlat added to the stats/charts.
brgds/evangel
chrisc550
Quote from: IanH on January 27, 2017, 12:26:54 PM
Last version that I have for RPi1 is the same as you: 20150825.
Perhaps the RPi1 was not powerful enough to run the extra options so no newer version?
Edit:
Found a slightly more recent version (20160119) on a Russian forum
http://forum.adsbradar.ru/f25/modesmixer2-windows-linux-com-tcp-mixer-transcoder-modes-1451/
The file listing is not in Russian  ;)
Good find, IanH! Thanks for the help, I appreciate it :)
chrisc550
Quote from: sergsero on January 27, 2017, 12:55:16 PM
Hello,
I'll try to compile a version of modesmixer2 for RPi1 this weekend.
I fully agree with IanH, that for use extra options it is desirable have RPi2 or RPi3.
However, the main difficulty is to maintain on the deprecated version of Debian Wheezy 7. Today the current version is Debian Jessie 8 and it would be preferably to switch to it completely.
Because for building and optimizing programs I need a modern version of the gcc compiler and libraries.
Hi sergeso,
Thanks for compiling your latest version for RPi1! I understand that it's a pain to maintain for old hardware and OSes so I appreciate the extra effort you took. This version should last me until I can switch over to a newer model, so I won't be expecting any future updates for this old architecture in the future.
chrisc550
APO1972
Hello to all,
Today i updated my modesmixer2 to v.20170127 without changing my .bat file.
Then after i observed that the "source id" dissapeared from the aircrafts coming from my local source...to all others whose coming from remote sources appearing well.
***UPDATE***
I don't know how? , but from yesterday i've left it as it was and today working well!!!
grezz
Hi sergsero,
I am trying to run modesdeco2_rpi2-3_20170127.tgz on an rpi 2 and I get "error while loading shared libraries: libyeppp.so: cannot open shared object file: No such file or directory"
I can't find a source for Libyeppp.so - i've tried the yeppp.info site but it seems to be down.
Hi grezz,
I'm sorry, in this archive was erroneously placed the test version in which was used the dynamic library. Now I replaced the file. Please, download the archive again:
https://drive.google.com/open?id=0B7NYXizl0U6iNWJpQk5LTUktZ0E
Thank you for found an error in the archive.
larsras
What is wrong with my data here?
I often have a number of planes (especially Norwegian I think) that is not displayed with all details, in the ModeSMixer2 (20170218) Flights list. It is "Register" and "Type" that is empty (and then also the silhouette as Type is missing). If I do a lookup in Basestation.sqb it looks like I here have full details on the plane (incl. ID and Type), by searching on the ICAO code. I guess Basestation.sqb is used, but is there also some online lookup involved?
br Lars
Are you certain that you are telling ModeSmixer2 to use the correct basestation.sqb?
If you have several on your PC, it might be reading from a different one to the version you are looking at!
larsras
Yes I am, and I only have one version on my PC. The lookup works in 95% of the flights I have displayed. In this moment I see 29 ADSB and 12 ModeS. I have 6 planes right now where the Register and Type is missing, and 4 of them ar Norwegian(NAX)/Nortrans(IBK), and two KLM. I have tried to do a lookup in the basestation.sqb for the NAX/IBK and all 4 can be found with all information displayed.
Do you run Basestation too?
What's the folder path for your sqb file?
larsras
Actually I can see my signature was outdated. For a long time I have only been using ModeSMixer2.
c:\Apps\BaseStation.sqb
and command line in startup includes:
--db c:\Apps\BaseStation.sqb
spotter.ssol
Suggestion: make a copy of your database into another folder, install and configure VRS to use it and see if the same behaviour occurs. This probably will point if the problem is the database or mm2.
Quote from: spotter.ssol on March 30, 2017, 02:05:10 AM
This is a good idea.
Can you also post a screen capture of any of the "missing data" records as viewed in the sqb?  What are you using to view these records?
larsras
YEs, great test. SO did a copy of current SQB into my VRS directory, and changed the VRS config to point to this.
