November 25, 2026, 08:12:04 PM
can i run sdr sharp and irtual radar server
Started by regchan, August 31, 2013, 09:58:35 PM
regchan
  right i know i can run sdr sharp on port 10001
but i tried running vrs on 30007 connects but no data coming from this port an i using the correct port ???
so to summarise  this up in one what other port can i use besides 10001 for  VRS
i have noticed a slight problem running SDR sharp and base station together  seems to lags slightly
helpful and can help in any way
Have you set the data port in VRS and tested the connection?
regchan
tried 10001 work very well for vrs  30007 im not sure it does not seem to populate  i believe but seems not to work i have a feeling it should but sdr sharp has to use port 10001
