November 25, 2026, 09:12:13 PM
hello seems like i got a crash with operator flags
Started by regchan, September 04, 2013, 12:43:30 AM
regchan
this has also been posted on kinetic
ok right seems like every time i load up my basestation it crashes
i have a zip folder for download called operatorflags-fault but my other flags folder work fine but the new updated one has all flags i want to use ???? problem please help
url from @Dropbox http://db.tt/TpHXQySW files here is faulty for me but would like an insight to why please test this just loads of imgs about 10.000 +
reggie
regchan
helpful and can help in any way
You probably have a rogue file in your folder.  But if they're in a folder called "Operatorflags-fault", Basestation will ignore it.
You can check the folder using BMPCHK in our Software section.
http://radarspotting.com/forum/index.php?action=tpmod;dl=item95
regchan
i just renamed the folder for a reason keeps as faults for a reason
regchan
#3
ok it loads all the way butthen it crashes im going to try tonite on a clean install on other pc      i have 16 GB ram on this pc
is there an up to date 2013 todays operator flags i may try on my system cos i know i got some missing flags with some one that has a working system
the working flags are ianks flags off the sbs recources  link  :o :(
Ian K
There is no current list.
The Operator flags only get added to as new one's appear and as far as I am aware there should be no rogue files.
regchan
ian is there a zip with all new operator flags so old to new 2013 ready for download
Ian K
