May 28, 2026, 01:17:45 PM
Map problem
Started by Radio2.0, October 20, 2013, 08:20:39 AM
Radio2.0
Hey
After a Crash all going wrong I dont know what happen but the Cross is on the top left side and pp load only the World Map.
How can i fix it?!
Try running ppregfix.reg located in the same folder as PlanePlotter.exe.
Radio2.0
Check your PP directory path for charts?
Radio2.0
I dont have chance them maybe after the crash some file are corrupt.
Radio2.0
Radio2.0
i have to make the same settings again.  That take a long Time and sucks.
Welcome to the world of plane plotter  ;D
Quote from: Radio2.0 on October 20, 2013, 11:32:36 AM
Well, if you take a backup of a working PP installation and also backup the appropriate Registry key, all you need to do is reinstall PP, copy back your charts, maps outlines etc. etc. and run the registry file and it will work just as before - certainly doesn't "suck".
The registry key you need is [HKEY_CURRENT_USER\Software\COAA\PlanePlotter] locate it using Regedit and then right click and select Export. Give the file a name - PP_Reg_Backup perhaps and save it somewhere safe. After re-installing and copying back your stuff, double click on the .reg file and it'll do the hard work for you.
The only caveat is you must use exactly the same drive and folder structure for the re-install as you did before you backed up the registry key.
Viel Glück,
