May 28, 2026, 06:29:44 AM
Move PP from XP system to Win7 System - how ?
Started by Dave_EGDR, November 15, 2013, 12:41:51 PM
Dave_EGDR
Hi all,
before I start thought it best to ask for some advice.
Want to move my current PP install from my XP box to Windows 7 box, but retain my current PP registration and code (xi)  Can someone detail how to do this please and anything I need to watch for.
Will be moving in total:
SBS3 Basestation, PlanePlotter and Active Display
Dave
Running SBS-3 and Planeplotter code: F4
satcom
Hi Dave
You need to start again , register / authenticate etc.
You can copy your chart files over .
If a GS/MU you'll need to request activation on the new code .... finally once all that has been done  if you then contact me via the group I will see if I can reinstate your old code.
Dave_EGDR
satcom
Hi Tim
We first used the registry key method some years ago when OS were a little less complex and varied...its worth a try , but unless everything on the new machine is exactly the same as on the donor machine , the key will fail.
Yes John, hence my emboldened comment in the link  ;D
Dave_EGDR
Did the slow reinstall everything method and I seem to be back up and running.  Just doing some testing then I'll contact you via group John regard GS/MU status and changing code from pC back to xi (if poss)
Thanks for help
Dave
