November 22, 2026, 12:08:11 PM
BaseStation 184 - audio toolbar not working
Started by IanH, February 07, 2014, 04:57:04 PM
Chris-G0WTZ
If you have upgraded the exe file you will retain the ini settings for your radio.
In the past the SDR on the SBS-3 was internal
You now have 3 options SDR,Internal and external
If you go to Settings Toolbar
Uncheck internal
Uncheck External if selected
Check SDR and then restart basestation it will save the SDR to your ini file and the buttons will work
Hope that helps
Chris-G0WTZ
Rob they will because the SBS-1eR is internal and SBS-3 is now SDR !
G4UMW
Rob/G4UMW
OK, Chris has phoned and explained the issue, although I didn't upgrade the exe, mine was a clean install..
If one has an SBS-3, the icons have to be "activated" by telling BaseStation that you want to use its SDR.
See the screenshot.
It appears that SBS-1eR customers don't experience this issue as the Internal Radio is checked by default.
Methinks a small problem of "usability" for Kinetic to ponder.
Quote from: mhm on February 11, 2014, 08:17:26 PM
The puck alongside the SBS-1
The SBS-1 doesn't have a radio so these icons won't work.
What Toolbars do you have ticked when using the Puck SDR?
Ok, from Toolbar options turned off "Internal Radio" and enabled "SDR".
Now working fine. As Mike says "useability" seems to be obscure - once you know, it's a "doh" moment. None of us worked that out!
And I've only ever operated an SBS-1e from this PC so the defaults were applied even though there was no radio.
What's even more annoying is that I actually read the manual for BS184  ???  and the subtle distinction between internal and SDR is sadly lacking. All that is mentioned is "If the built-in SDR toolbar is not visible...". Well it was, just the wrong one and since they are identical, that gives no clue.
Anyway up and running now so moans over.
Chris-G0WTZ
MHM please call me in the office so I can change your unit for a later version which will work
