November 22, 2026, 12:06:22 PM
how to add waypoint
Started by kl692, February 12, 2014, 12:24:56 PM
kl692
Hello All, I am new to basestation and I was wondering how do waypoints . I basically want to see the runways of home airport with is CYYZ.
Thanks in advance
Ernest
Truetrack
Hi Ernest
you may be interested to look into or use AIRAC Waypoints for SBS-1/-3 and RB
autogenerated on demand, check http://jetvision.de/airac.shtml
as you mentioned runways these are in category outlines of which I do not
have any current URL. Rod Bearden used to post a listing for originally RBox,
but files work in SBS as well.
May be other readers know more where to find those.
regards
Klaus
For runways you need Outline files.
Active Display Lite (free) from the Gatwick Aviation Society has a library of runway outlines and I have a large collection too if you can't find the ones you need.
Send me a PM.
kl692
Quote from: Anmer on February 12, 2014, 05:36:03 PM
Send me a PM.
Sorry for the long delay in replying, I work at night so i am not up doing the daytime and the 5 hours difference in time doesn't help.
I happen to found one outline and way points which must have placed over 100 lines in on my screen. Very hard to see anything unless I zoom all the way in. The outline for YYZ runways where off and it was basically just a line. I am wondering if there is something close to the picture below out there.  Thanks
Ernest
Here is a screenshot of an Outline file for Toronto.
These airfield outline files can be downloaded using Active Display Lite as mentioned in an earlier post in this thread.
kl692
Quote from: Anmer on February 13, 2014, 08:03:57 AM
That is sweet, I have active display lite install but how do I download it? and what is that software good for?
In AD Lite go to BaseStation Configuration -> Install/UnInstall Outlines and Waypoints and then select Canada and the airfields you want to install.
Make sure AD Lite knows where your BaseStation folder is located.
kl692
Quote from: Anmer on February 13, 2014, 09:21:47 AM
Thank you Sir, I will do that I as soon as I get home from work.
kl692
Hi, I did as you said and it works. Thank you very much
Ernest
