May 28, 2026, 02:08:11 AM
New Version Of PlanePlotter...out now !
Started by satcom, February 21, 2014, 09:49:28 AM
satcom
PlanePlotter version 6.4.1.5 is now available for download following
the link on the PlanePlotter web site.
---Usual boilerplate---
You may need to exercise your browser Refresh function to force it to
show you the new version of the PlanePlotter web page. If you post a
message saying that the web site is still pointing to an earlier
version, you pay a forfeit !
You can install the new version over the old one but you *must*
close/exit PlanePlotter before installing the new one. Your settings
will be preserved. If you post a message saying that the installer is
unable to replace planeplotter.exe, it means that you did not close
PP first and you pay a forfeit !
If you have a version-specific firewall (eg Zone Alarm), you may have
to reassure it that the new version is permitted to access the Internet.
New in version 6.4.1.5 - in no particular order
Server connection warning
The server connection warning now shows in the
status bar, rather than a pop up dialog to avoid hanging unattended instances.
OLE/COM method GetDesigData(27)
OLE/COM method GetDesigData(27) was a short
integer so could not report target altitudes
above 32000ft.  It is now a full integer.
Shared longitudes outside of +/-100°
shared longitudes outside of plus or minus 100
degrees had only three decimal places, which
misplaced aircraft at large scales in these far
east or west longitudes.  (This was actually fixed in the server script)
TCAS alerts
TCAS conflict alerts now appear in Alert
box.  Thanks to Blort for guidance on this rare message format.
Trap lockout of alert checks
Alert checks could previously get into a lockout
state under some circumstances of marginal
Internet connection.  This version may solve that problem.
Secondary sharing server
An additional option to upload data to the AirNav
RadarBox24 server is added.  Note that these
secondary sharing options consume resources and
enabling all the secondary sharing options with a
very short cycle time will most probably lock
PlanePlotter.  Only select options that are
required and use a share cycle time of 60 seconds if possible.
New OLE/COM methods
GetWanIp() is a new OLE/COM method.   It returns
the WAN IP address as seen from the PlanePlotter
server.  It returns a blank string if no Internet
connection exists.  Note that if the system is
working behind a router, it yields the WAN IP
address on the server side of the router.  If you
are behind a router belonging to your ISP (ie
given a LAN IP address for your network), then
the WAN IP address may not be useful.
RefreshOutlineColours() is a new OLE/COM
method.  It re-reads the outline colours from the
registry and re-draws the outline if an outline
is being displayed.  This allows external
processes to change the outline colours and for
the new colours to be displayed immediately,
rather than only after restarting PlanePlotter.
QNH button
The QNH button now reloads the QNH from the
server rather than from a local cache so it will track changes of QNH.
Bev
COAA
Updated with no problems, as is the norm.
Thanks for posting the info here, I find the Yahoo! group more and more difficult to read every time they 'improve' the interface and I've pretty much given up trying to follow it.
I appreciate all the effort that goes in to PP, thanks chaps.
satcom
Than ks Keef....there are some nice updates in the version including TCAS alert.
Experience indicates these are few and far between , but if you spot one , let me know.
QNH should also now hold regardless of where you move your chart area to , so you don't have to reselct QNH if you  redraw/move your chart/outline
Breitling
Same thoughts about Yahoo group.
Two instances updated without problems, testing now the new features.
John,
Is there anything to 'set' to get the TCAS alerts - I looked in the usual places Options>>Alerts>>Alert Fields, Chart Options and didn't see anything. I appreciate they may never occur but if they do, I want to be sure I see them.
satcom
I didnt do the testing on this Tim , so I am seeking more info from Bev , but AFAIK there is nothing to select , the alert should come up in the pop up alert box .
Personally I would like to see the TCAS alert radiate as does the sqwk alert , but as soon as I know more I'll let you know.
Many years ago I posted on the PP Yahoo Group that we needed a better platform for PP support.
I still bear the bruises from the response.   :o
satcom
Quote from: Triple7 on February 21, 2014, 11:28:34 AM
John,
Bev reports........
There are lots of formats but the Alert window should show whatever
there is of interest.  It could be the hex code of the conflicting
target or it could just be the squawk code and the estimated range and bearing.
These are extremely rare  so don't expect to see too many ...... and are by the way only seen on local traffic.
Thanks John,
I assume therefore, we need to have Hex code and Squawk selected in the Alert Fields box.
satcom
Yes , I usually run with  hex , sqwk , c/s , reg and type but thats a personal preference
A bit quick on the e-mail telling me I am using an old version of PP. ie 6.4.1.4  ???
satcom
just sent out over 1000 of 'em , so you're not alone  8)
QuoteAn additional option to upload data to the AirNav
Clearly a much requested update  ;)
But possibly, in this day and age of litigation, have to be seen to be democratic? Otherwise a nice little earner for the B person!
satcom
Bethsalem
Hint - flies a Boeing and keeps telling everyone that the long awaited bug fixes will be released soon....very soon.....okay every four years  :P
