September 24, 2026, 09:45:00 PM
Message Filtering...
Started by APO1972, March 07, 2014, 02:37:45 PM
APO1972
Hello to all,
I'm wondering if the options in menu "Data Settings" ,can make any difference in the reception of the old devices(SBS-1e & SBS-1er).
With the newer SBS-3 ans SBS Puck what will be the difference?(decoding MODE a/c/s ,ADS-R ,TIS-B)
Also , are there TIS-B and ADS-R messages in Europe?
I have an SBS-1 MKI and i saw latelly , a lot of aircrafts only with MODE-S that sends their Call signs,Squawks and the current altitudes.
Thanks a lot
There's no TIS-B in Europe and ADS-R doesn't apply outside the USA.
APO1972
So...the only things remain are MODE A/C...what will be the benefit if i bought for example an SBS PUCK?
Will the aircrafts with only MODE A/C show up in list to the right???(CALL SIGN,REGISTRATION,SQUAWK AND ALTITUDE)
Quote from: APO1972 on March 07, 2014, 06:52:13 PM
No they will not.
The BaseStation "aircraft list" only lists those transmitting Mode-S data on 1090 MHz.
APO1972
So , if i understood well...I will not have any benefit if i purchased the new SBS PUCK(and not SBS-3 because i don't care about AIS and SDR),or the olders SBS-1e,er.
My SBS-1 MKI doing its job very well! ;D
Thank you very much , because you solved my questions very quickly!
The Puck uses the same Mode-S "receiver" as the SBS-3.
The Puck may decode a few more messages that the older SBS-1 model range.
The main advantage is the Puck's small "footprint" and low price compared to the SBS-3.
If you have a working SBS-1, 1e or 1eR, there's not much benefit in buying a Mode-S Puck.
But that's just my personal opinion.
APO1972
But why SBS PUCK or SBS-3 can't decode MODE A/C...i red that on the internet site "http://www.airsport-corp.com/modec.htm" for the aircrafts transponder : a) the interrogation pulses "ask" from Radar are transmitted on 1030 Mhz and b) the output of the transponder "reply"  is on the frequency of 1090 Mhz...
G4UMW
#7
From the user manual (with acknowlegement to Kinetic):
Relay Mode A/C Messages: SBS-3, 1090 Puck
This checkbox enables output of Mode A and C data on BaseStation's raw data output over Ethernet (port 30006). BaseStation does not currently use Mode A/C messages itself but they can be used by third party applications connecting to this port. Enabling this option will increase data bandwidth significantly.
Rob/G4UMW
APO1972
OK  i understood..like PP(Planeplotter)
