May 27, 2026, 05:28:42 PM
Spotting military aircraft
Quote from: IanH on April 11, 2014, 12:09:44 PM
Last message probably for Tibo rather than me  ;)
Oops - yes, Sorry Ian.
Quote from: TTECH on April 11, 2014, 01:53:33 PM
Quote from: viking9 on April 11, 2014, 11:56:01 AM
Ian,
Have you selected 'View/Chart display options/Beamfinder' and ticked 'Beamfinder labels'. If you do, do you see the radar ident codes in the labels of any non-positional aircraft?
Yes it it checked.
Where can I see the ident codes in the Aircraft List?
Tibo,
You cannot see the ident codes in the aircraft list but you will be able to see them on the chart.
You must click on the Chart Options icon (blue spanner on green background) and then in the window headed 'Labels'. tick the box 'IID'.  The ID should appear in the label for all aircraft seen by your antenna including non-positional ones shown by mlat sharers.
If you double-click on any aircraft in the chart showing radar ident code then you should see the the beams from that radar head.
Having said that, sometimes the beams take a while to show, sometimes they show as intercepting a different aircraft than that chosen, and sometimes the beams do not show at all.
TTECH
I can see the IID numbers.
In the attachment is a picture of it.
Not very accurate but I have to tweak the radar.txt file.
Tibo
Well it looks as if you are doing just as well as I do with my SBS-3.
TTECH
Hmm okay, maybe I am expecting too much of it. ;)
Radio2.0
i see a lot "mil" flight but the use only the mil code for there flight.  >:(
And i see some heavy mil aircraft.
TTECH
Does anyone know why I am not receiving Alpha Jets that are flying around me?
I am using the R820T dongle on ADS-B/Mode-S.
Maybe they're using Mode-AC?
Not all aircraft have Mode-S transponders that will transmit data or respond to interrogation requests on 1090 MHz.
TTECH
Okay, will there be a way to receive them? Any reason why they don't respond?
Strange that they don't use it as I can receive most of other BAF aircraft.
Breitling
Just a little point on that: all interrogation requests are done on 1030 MHz, both mode S and mode A/C. Aircrafts always respond on 1090 MHz, both modes again. We are only able to receive aircraft response messages.
Alpha Jets are old aircrafts equipped with old avionics, sure they are not migrated to mode S. Remember it is not mandatory in Europe until 2020. You can receive them on mode A/C, but all you get is a transponder code and altitude.
Quote from: Breitling on May 06, 2014, 10:17:03 PM
As I said, "respond to interrogation requests on 1090 MHz".  Meaning the resposne is on 1090 MHz.
TTECH
Thanks for clearing that up :)
It seems that the R820T can't receive Mode-AC and Mode-S at the same time?
Breitling
#102
Quote from: Anmer on May 07, 2014, 06:12:28 AM
Ok, sorry Anmer. As english is not my mother tongue, maybe it's me failing to get exact meanings at sometimes. I'm pretty sure in ocassions I write down expressions that make you all open wide your eyes   ???
Breitling
Quote from: TTECH on May 07, 2014, 07:29:42 AM
Yes it can. I'm doing it now using sergsero's ModeSdeco2 software.
TTECH
And is it possible to use it at the same time when using PlanePlotter and Dump1090?
I still want to use Dump1090 as it provides useable raw data with the R820T for PP.
