May 27, 2026, 08:30:30 PM
help no planes
Started by GED, April 21, 2014, 05:39:35 PM
GED
Did you read the PGR Guide that I posted the link for?
GED
yes thats the guide ive got and used to set it up,just cant see whats wrong
#18
When you installed, you did use the Win 7 drivers and not the XP ones I assume?
Have you fiddled with the gain settings from within PP?
GED
Quote from: Triple7 on April 21, 2014, 07:12:13 PM
erm have to be honest and say dont know ,i just popped in the disc and of it went,i have checked device manager and pgr has the latest drivers and working fine,although it seems not to work
OK, if it was an auto install it should have been OK. I was wondering if you had chosen the drivers manually when you did the "browse my computer for driver software".
Does device manager say 'This device is working properly'?
GED
yes tim device manager says pgr is working fine ,even pp says my router settings are fine,which is what i thought i may of got wrong
You said that Comm 3 is the one set for the PGR, is that confirmed in PP via Options>>Mode-S receiver>>PlaneGadget Radar>>Setup  Comm Port?
Also does anything change of you look in Options>>Mode-S receiver>>PlaneGadget Radar>>Setup receiver and then select the factory default settings button?
GED
Quote from: Triple7 on April 21, 2014, 07:38:38 PM
tim pure genius  it now works,feel like a right berk,although i did want to know if there was a chance of double checking the port through pp not device manager ,great stuff ill make a donation to the forum really am greatful to you all
You are most welcome GED, I for one am glad you found the right forum to ask for help. There are others but they are nowhere near as helpful or friendly as this one.
Happy spotting / watching / decoding or whatever your passion is
Thanks Tim, well done.
