May 27, 2026, 07:06:02 PM
PlanePlotter on two computers
Started by TTECH, April 23, 2014, 12:19:00 PM
TTECH
That's some good news, satcom!
Looking forward to the release  ;)
If it all works correctly, I think much more spotters would buy a R820T dongle and use it with PP because that is the cheapest option.
Tibo
satcom
Quote from: Anmer on April 26, 2014, 08:17:48 AM
Quote from: Triple7 on April 26, 2014, 08:15:32 AM
As I mentioned in reply #5 I have a Huawei E585 MiFi router:
Thanks Tim.
My question was primarily directed at Satcom.
Hi Mike
The model I have is about 5 years old and  works really well
Its the ZTE MF627 USB Modem...
I have used it across the Uk and its fine provided you are in a good  "3" reception area.
It has been running for the last two days acting as SMU across BeNeLux and creating  3-5 mlats per sixty second cycle with ease.
TTECH
All going good, Satcom?
I have found  potential people that want to use PlanePlotter in Belgium  :)
They ask me which receiver is the cheapest for providing Mlat data?
I personally would suggest the R820T but as it can't provide Mlat data with Windows at this time, I don't know if it's a good choice till the new PP release.
satcom
Hi Ttech
Great work...we only need  four or five new ground stations in Belgium to get some good fixes.
Mlats are already being created , but mainly to the north of the country.
The dongle is certainly a good device to start with , perhaps eventually some will upgrade to SBS or Beast.
Meanwhile.....I am still waiting to hear from Bev and the developer of Dump1090 for PC
with regard to a release date.
Could you PM me  john@satcom.freeserve.co.uk
TTECH
Hello satcom,
I don't think they well buy a SBS or Beast at this moment so I will suggest a R820T to them or is there anything under €100 that will work for Mlat data?
At this moment, are you sure the new version of PP and Dump1090 will make the R820T suitable?
Good luck.
Tibo
satcom
If you PM me as above I will run some tests for you
John
TTECH
TTECH
I am looking around for a 3G dongle.
I have a few questions:
- Three.co.uk's network has no coverage in Belgium, if I can believe their website, so I will have to use a Belgian mobile provider like Proximus.
---> To use Mlat, I will need to be able to port forward and have a static IP adress.
- So I will have to contact my mobile provider to ask if they use static IP's and I need a 3G dongle that can do port forwarding?
- Has 4G an advantage above 3G for PlanePlotter or should 3G suffice?
I have found a cheaper dongle but I think it hasn't port forwarding:
http://www.mobielinternetstore.be/product/212806/category-189668-top-5-dongels/proximus-huawei-k3806.html
Tibo
TTECH
Quote from: TTECH on May 04, 2014, 11:07:52 AM
As far as I am aware (happy to be corrected here) you don't need both a static IP address (WAN IP address) and use port forwarding. If your ISP gives you a WAN IP address then there is nothing to forward, as any data can only be sent to the one attached device. If however you don't get a WAN IP address you just get a LAN address on a shared WAN address, then you will need something that can port forward, e.g. the E585 mentioned above.
Quote
see above
Quote
I have only used 3G and it works perfectly well for me
Quote
You can't tell by looking at it but it looks to be a simple dongle to me and then the IP address allocation depends on your provider.
I have a spare E585 if you are interested, it is currently locked to the '3' network but a quick Google search found this which seems to be a pretty straightforward way to unlock it:
http://m0nkeycheese.blogspot.co.uk/2011/04/australian-huawei-e585-free-unlock.html
PM me if you are interested in the E585 and we can discuss.
TTECH
Thank you for the answer, Triple7!
I will try to ask some Belgian ISP's this week if they use WAN IP adress or a LAN adress on a shared WAN adress.
I will first take a look at some other dongles before buying a used one.
I will keep you updated.
TTECH
I have a reply from someone of the Belgian ISP's:
Quote"You will get a dynamic WAN IP adress, and it depends on the dongle if you get a LAN or WAN IP adress."
- Is it a problem when the WAN IP is not static?
- It depends on the type of dongle?
TTECH
I am testing PlanePlotter on 3G network.
As I can't use Mlat when using 3G, will my R820T dongle supply raw data when using 3G or are there any benefits why I should use the R820T dongle when using mobile 3G network (I cant do manual Mlat with my ISP)?
Otherwise I won't use the r820t dongle when mobile.
