May 27, 2026, 07:49:23 PM
Planeplotter settings
Started by faithle55, May 01, 2014, 05:23:01 PM
satcom
Quote from: Anmer on May 01, 2014, 07:59:13 PM
Quote from: Triple7 on May 01, 2014, 07:56:34 PM
Indeed it is!
damn glasses.
Lend them to Satcom.  :)
Don't need 'em , my instructions were correct
satcom
Quote from: faithle55 on May 01, 2014, 08:06:13 PM
Quote from: Triple7 on May 01, 2014, 07:52:43 PM
Hmm c'mon John, you're the resident expert.....
It's actually
Options>>Mode-S receiver>>Kinetic SBS family>>SBS3-Direct address
Then as you have it
Type in     127.0.01:30006
;D
Problem, if I do it as that Tim, even with the correct 127.0.0.1:30006 it turns all my plots off
If I do it Satcoms way, I keep my plots but now have the decending flight levels
Getting more confused
Nige
Isn't that what you wanted Nige ?
If in doubt its all in the wiki
faithle55
Thanks for all you help this evening. Its behaving better than before, got a few more things to sort out like correct plane symbols on screen and in the planeplotter lists. Sadly playing around with files is not my strength.
Nige
satcom
Its quite a learning curve Nige , but then the software provides just about everything you need...and more
Take things slowly and gradually build it up to your specific taste...and don't forget that  there is also the PlanePlotter Yahoo group with a files section , plus the Online Help via the Help tag in the software...plus Nic Storey's great  tutorial videos
http://www.nicstorey.co.uk/planeplotter/Home
Quote from: satcom on May 01, 2014, 09:31:26 PM
Really?
Is your recommended IP address correct?
Quote
Can you please show me where under Options>>Sharing>>Set-up (per your instructions) there is an option to enter an IP address, as it isn't on my screen and never has been. Hence I corrected your post to show Options>>Mode-S receiver>> etc etc.
