May 27, 2026, 07:49:03 PM
Planeplotter settings
Started by faithle55, May 01, 2014, 05:23:01 PM
faithle55
Has anybody got a screen shot of the "Input/output settings" table on planeplotter ?
Not to sure if I have all the right box's ticked. I am running a SBS-3 24/7 and sharing to PP via good internet. Picking a lot of MLATs up myself if I do the manual MLAT but not showing much unless in do it myself :(
Any help would be good
Nige
Bethsalem
Hi Nige
Make sure you've ticked "download positionless data" in "Sharing".
Stephen
faithle55
Thankyou Stephen, was a couple of boxes I hadnt had ticked, hopefully that will help :)
the only other one I am not to sure about is in the drop down box, if I need to highlight the
SBS1/RBv3 TCP
or
SBS1/3 direct TCP
Nige
satcom
SBS1/3 direct TCP will give you all the extra features that Basestation doesn't provide
make sure that you also allocate the port 127.0.0.1:30006
BTW there have been 70,000 mlat fixes so far today over the UK
faithle55
Just stuck it on the SBS1/3 direct and have no RAW data out, so is that because I also need to allocate that port, already done the other UDP/IP local port to 9742
Have you set port forwarding for 9742 in your router?
faithle55
Yep, port forwarded 9742 to the computer and have fixed a static IP address to the one running PP
In I/O Settings have you checked "Allow Auto Mlats" and "RAW data for Mlats"?
faithle55
satcom
In options sharing setup
Mode S receiver
Kinetic family
SBS3 Direct IP address
Type in     127.0.01:30006
OK that stop and start PP
You should now see[on local a/c ]
Cleared to alt
Upper air temp / pressure
Wind rose/direction vectors
etc
#10
Hmm c'mon John, you're the resident expert.....
It's actually
Options>>Mode-S receiver>>Kinetic SBS family>>SBS3-Direct address
Then as you have it
;D
Surely it's
127.0.0.1:30006
Not 127.0.01:30006
Indeed it is!
damn glasses.
faithle55
Quote from: Triple7 on May 01, 2014, 07:52:43 PM
It's actually
Then as you have it
;D
Problem, if I do it as that Tim, even with the correct 127.0.0.1:30006 it turns all my plots off
If I do it Satcoms way, I keep my plots but now have the decending flight levels
Getting more confused
Nige
