October 27, 2026, 08:54:04 PM
BaseStation loss Operator Flags.
Started by mw0cvw, May 22, 2014, 11:34:27 PM
mw0cvw
Hi Everyone,
Lost the Operator logo in the base station column for some reason.
Confirmed the flags are contained in the Kinetic\basestation\operatorflags folder.
Any suggestion would be much appreciated,to fix this problem.
Kind Regards
Paul  Mw0cvw
EGGP/EGNR Ground Station Ug
G4UMW
#1
Paul,
Do you mean that you've lost the Operator column in the aircraft display? If so, from the toolbar select Aircraft -> Columns and check that the Operator Flag option is ticked. You also need to ensure that the Operator Flag Code field is populated in your SQB file and also that your flags loaded correctly (check the splash screen during the BaseStation boot sequence).
HTH,
Rob
Rob/G4UMW
mw0cvw
Rob
The Column is being shown correctly in Basestation but the Operator Flags have vanished.
Have checked the required folder which contains the operator logo.
Will do some further investigation :)
Paul MW0CVW
EGGP/EGNR Ground station Ug
Click on an aircraft record in Basestation and check the OperatorFlag field has a matching BMP file name, such as BAW for BAW.bmp.
If it has, check the OperatorFlags folder for a rogue file using BMPCHK file checker.
See:
http://radarspotting.com/forum/index.php?action=tpmod;dl=item95
mw0cvw
Your thoughts where completely correct and the utility was a big help.
Operator flags not being displayed in BS as required.
Where can i get the latest logos from,have searched theWeb but they do seem a bit out of date.
Thanks again Anmer & everyone for the support much appreciated.
Paul
Mw0cvw
Quote from: mw0cvw on May 23, 2014, 07:56:29 PM
You will find may here on the right-hand panel under Links & Files.
