October 14, 2026, 05:38:48 PM
ADL Fieldlength issue (Registration Field)
Started by Truetrack, May 25, 2014, 12:31:39 PM
Truetrack
ADL Fieldlength (Registration) problem
Having Basestation customized with some fields in Aircraftlist pruned
but the Reg-field enlarged to enable either prefix or affix e.g.
(FNF) PI-06
(Slov) L9-64
(AFP) 16711
G-OUNI o/ID  (as still showing German modeS 3D08FE )
This in conjunction with my BS-SQB, BS-Reporter and SQL-Browser
working fine.
Only recently installed ADL Beta and have it run parallel,
however ADL is halting when my SQB is offering a longer reg than
ADL's maxfieldlength of 10 digits for regs.
This is annoying to press 'continue' and 'start' again.
Looked for some ADL .ini but could not find anything to tweak
Question now - is there a means to enlarge the internal maxsizelimit of reg-field ?
(Pulling the column wider is not the clue)
Klaus
I suspect the field length is defined in the program code.
So only the programmer can change that.
