October 15, 2026, 05:55:11 AM
FD error message.
Started by charliebrown, May 29, 2014, 11:38:06 AM
charliebrown
I have started getting the  attached error message when I shut down FD.
Also getting the "There have been more than 10 internet errors - Press Start Button to restart look ups".
Any suggestions what is causing this.
Using BaseStation 185 with Kinetic 1090 and SDR pucks.
Charlie
FD is seeing Internet Errors when connecting to an external resource, typically a route lookup.
Check the Internet Errors txt file which should be in the UserData folder and check which one it is.
charliebrown
Hi Mike
Thanks for getting back so promptly.
I have attached a couple of FD files as there seems to be lots of internet errors.
Charlie
Disable the Flightstats lookup and see how it goes.
That's the problem with FD, it's not supported so when a remote site changes, the lookup script in FD fails.
charliebrown
Hi Mike
I have un-ticked the Flightstats box in FD.
I'll see how that works.
Charlie
charliebrown
Hi Mike
With Flightstats box un-ticked in FD, the attached error message was generated when I closed down FD last night.
Charlie
Did you close down Basestation before FD?
charliebrown
Hi Mike,
Closed down BaseStation then FD.
Charle
That's why you got the error message.
charliebrown
Hi Mike,
Thanks for that - will shut down FD first from now on.
Charlie
