May 19, 2024, 02:46:15 PM
You should get an activation email when you join.Ā  If not, please use the Contact option.
modesdeco
Started by Anmer, May 31, 2014, 08:55:29 AM
Does anyone know if Sergsero's modesdeco works with a RadarBox receiver?
I don't know.
And I know this a bit of an off topic comment, but I would like to extend my thanks to Sergsero for all his efforts.
Thanks!
ModeSDeco is for the RTL-SDR dongles.
According to the thread on Radarspotters about ModeSMixer:
QuoteC:\>modesmixer2.exe --inConnect 192.168.0.2:30003 --outServer avr:30048 --outServer sbs10001:10001 --globes 31008:table2:mm2
allows to use source feed in MSG format which will be encoded to streams: AVR ASCII, BaseStation sbs10001 and Globe-S.
I hope the new option may be of interest to users of receivers that have only a MSG output, as ARNB.exe for RadarBox by AirNavĀ® Systems.
Which means an output from port 30003 of ANRB.exe can be converted.
Not tried it nor sure how useful that is.
Thanks Ian.
I was curious if it could take a native data stream direct from the RadarBox receiver.
