May 02, 2026, 02:03:04 AM
VLC Media player issues Windows 7
Started by mw0cvw, June 07, 2014, 09:27:33 PM
mw0cvw
Hello Guys
VLC Media player version 2.1.3, has stopped working,cannot stream audio from SBS-3 over ethernet to PC.
Base station (Hardware Settings)
RTSP 3009
Default UDP Port 5004
RTP/UDP Streaming is 127.0.0.1
Destination Port 1234
Note:Base Station working as normal displaying aircraft on screen.
VLC Media Player Settings
Media Network Stream rtsp:// 127.0.0.1
Have cycled power on SBS-3 and re-loaded the software (VLC) and base Station several times.
Any Suggestions would be very welcome  ;D
Paul
Mw0cvw
EGGP/EGNR
Ground Station UG.
Try adding the port number to the VLC command:
Media Network Stream rtsp:// 127.0.0.1:3009
mw0cvw
Ian,
Tried that before rtsp:// 127.0.0.1:3009.
VLC advises it cannot connect to 127.0.0.1:3009.
Back to the drawing board,appreciate the comments and support.
Paul
MW0CVW
mw0cvw
Cycled power SBS-3 several times,and it just started to work.
Paul
MW0CVW
Is it really port 3009?
Default SBS-3 value is 30009
Three zeroes in the middle.
Check SBS-3 and the VLC valus.
acarslogger
Hi all,
.. audio data is on 30005.
My understanding is
30003 ASCII ADS-B data
30004 <is this used ?>
30005 Audio data
30006 Raw data
30007 AIS (Ships)
30008 Acars
30009 I+Q data (for SDR#)
Stuart
Because of all the port confusion, I actually changed my "RTSP Streaming" port under "Hardware Settings" to my own value (30025). That works for me in VLC and SM Player.
Since the default is 30009 and the suggestion is that this is for I+Q data, is it worth changing to see if that works for streaming?
G4UMW
#8
My audio stream works perfectly on port 30009.
Rob/G4UMW
mw0cvw
Hi Guys
VLC now working with SBS-3 and streaming audio via Ethernet.
Tried VLC to run on pc at startup,but does not like it for some reason.
Thanks Everyone for great Information and comments.
Paul
Mw0cvw 8)
