November 21, 2026, 06:00:52 AM
Faulty Dongle? Faulty Software? Faulty ????
Started by LX-LGN, June 25, 2014, 03:26:11 PM
LX-LGN
Not sure what the problem is.
Running Windows 7.
Using a DVB-T Dongle and RLT1090.
Rebooted laptop and reinserted the dongle as well.
Worked on Saturday.
Today not working :(
Below are two screen dumps from the rTL1090.
Anyone can help me with what might be the problem please.
What's the problem?  Is RTL1090 "stalling" during launch?
LX-LGN
#2
Launches ok but appears to get to the line below in Mode-S
"DO260A then some symbols
Started"
then stops doing anything :(
Tried clicking on Mode-AC it's blank :(
LX-LGN
Right I clicked the [TUNER AGC] button and it has sprung into life BUT
1. the Mode-AC looks like this:
It does not look complete :(
2. the Mode-S looks like this:
I'd try a fresh download of RTL1090 into a different folder and launch it from there.
If you get the same results, maybe the DVB-T has an issue or the antenna connection is bad?
LX-LGN
LX-LGN
oK I have installed the RTL1090 into another folder and added the associated file and getting the same displays :(
LX-LGN
Darn.
Looks like no ADSB for me until late August. :(
Thanks Anmer.
If i get anther Dongle ... I assume that as I have already done all the set ups before I can just plug it in ?
RTL1090 appears to recognise the DVB-T so a replacement should be OK being "just plugged in".
LX-LGN
LX-LGN
Brand New Dongle ... exactly the same problem :(
Ideas please  :'(
Do you have an alternative PC you could try?  Installing Zadig first.
LX-LGN
I have reinstalled Zagzig.
I have downloaded and reinstalled RTL1090 - IMU (Installer and Maintenance Utility)
I have rebooted.
And still getting the same corrupt data :(
Quote from: LX-LGN on July 07, 2014, 07:17:00 PM
On the same PC?
If the drivers are messed up, I have yet to find a solution to remove them and reinstall from Zadig.
Do you have a different USB port you can try?
