November 15, 2026, 09:30:23 PM
ADpro 5.1 Reference.sqb wanted
Started by russ1364, August 06, 2014, 12:43:38 AM
russ1364
Hi After renewing my subscription and updating to the latest version, I can not get it to update the Routes, various errors table missing, AR01,  AR02 AR03, etc, I edited and added tables with no avail, so basically can someone send me a copy of a working Reference.sqb file then I can replace the one in the folder and get this working proper again,
TIA Russ
windows 7 64 bit
Hi Russ,
Do you mean Reference.sqb.deploy?
Send me your email address and I'll send it to you.
#2
It might be worth closing down AD as well as all other apps, then  un-installing AD from Control Panel and re-installing AD to see if that sorts it out.
That should recreate the reference.sqb with all the correct tables.
Manually editing sqb files is a bit of a minefield, easy to get it wrong even if you're experienced (and I'm not!).
Here's a link to my reference.sqb if you want to try it...
http://1drv.ms/UY301v
Keef.
Duh, just realized Reference.sqb is in the Basestation folder. I couldn't find it in the Active Display one.
russ1364
Quote from: Keef on August 06, 2014, 09:43:43 PM
Keef.
Thanks Keef, Ive installed it into my BS folder will let it run for a while and see what happens, Im not to bad with sql as I have a couple of sites that I on it, so not to scary to edit, Thanks Again, Russ :)
