June 01, 2026, 06:22:08 AM
Airmaster 2000 Demodulator
Started by chimney1, March 25, 2012, 09:57:47 AM
chimney1
I have been running Airmaster 2000 for many years on Widows98.I still have software and demodulator to run this but it is on floppy .Could this be used on Windows XP and if so how would i configure it.regards CHIMNEY
Is the lack of a "floppy" drive the issue?
chimney1
No i have the floppy and demod so would it be easy to install say on  laptop running on vista or a computer running on XP? My old Windows 98 has packed up. How do i get the data from the floppy to the computer. Lacking some knowledge with the pc.thanks Anmer  Chimney
If you've got a floppy drive, you just need to copy all the files from the floppy to a new folder on the hard disk or a USB stick.
I wasn't sure if you had a floppy disk drive as they are quite rare (though I have a few here).
Sounds like he doesn't have the disk drive. He has the disk but not the means to read it.
Like you, I have several drives here - not used in a while but one should still be ok!
