April 24, 2026, 05:57:33 PM
AIP Files warning in PlanePlotter-
Started by Graham Bell, September 06, 2014, 09:57:06 AM
Graham Bell
Of late when I start PP or switch charts a window appears stating-
  "No AIP Files(having the `.aip extension) was found in your designated chart directory:C:COAA\Planeplotter\Chart Files\"
Click the OK option and the chosen chart shows correctly and PP works OK.
This problem appeared 7/10 days ago and I cannot link it to any action by me and I confirm that I am running the latest version and I reprise that this problem was there BEFORE this download.
As I have remarked I have not,intentionally,altered any settings and woud be grateful for any suggestions or advice.
Regards-
G.B.
I was getting that on a new install.
Under Options/Chart/OpenAIP overlay, untick anything that is already ticked.
Hopefully job done.
Graham Bell
Bless you Ian! Sanity restored and thank you.
Regards-
G.B.
hartg
 Hi, I have just encountered the exactly the same problem and followed the instructions but I do not find this...
Under Options/Chart/OpenAIP overlay. I have no Open AIP overlay showing. Please advise, with thanks.
Which version of PP are you running?
hartg
Tim, thanks and greetings from OOMS (Muscat). That's the bit I couldn't find being new to Planeplotter. All working well now. Regards, Geoff.
gcopter1
I have the same problem and followed the advice above but, it persists.
Quote from: gcopter1 on April 14, 2016, 05:47:11 AM
Are you getting the exact same message?  What version of PP are you using?
gcopter1
Yes, exact same problem, 6.4.4.5
Thanks.  Did you try IanH/Triple7 suggestions?
gcopter1
Yes, I un ticked them all but they keep coming back.
Might be worth checking your registry to see if all three REG_DWORD's are zero.
HKEY_CURRENT_USER\SOFTWARE\COAA\PlanePlotter
see screen grab.
