October 14, 2026, 06:15:30 PM
AD Lite Integer Error
Started by GlaMichael, January 25, 2015, 01:24:19 PM
APO1972
Good evening to all,
Today i decided to run 24/7 my RTL2832-R820T2 usb dongle , instead of my old SBS-1 MKI.
My setup is dump1090 --> modesmixer2 --> Basestation --> VRS and AD Lite.
The .bat files i used were :
dump1090.exe --interactive --net --modeac --net-beast --net-http-port 8088 --net-ro-size 500 --net-ro-rate 5 --net-buffer 5 --aggressive --mlat --ppm 53
pause
modesmixer2 --inConnect 127.0.0.1:30005 --outServer sbs10001:10001 --web 8888 --db C:\modesmixer2\BaseStation.sqb --location 40.64:22.93
PAUSE
exit
And in VRS    , Format : BaseStation and     Port :30003
Also i'm feeding FR24 with no pronlems.
But when i'm running AD Lite (BaseStation path is C:\Program Files\Kinetic\Basestation2\BaseStation.sqb which is the active one) ,unfortunatelly stuck and gave the integer error...What's going on? Where is the fault?
Before usb dongle , i run the SBS-1 MKI with the above setup and all worked perfect!!!
Thanks a lot
AD Lite needs Basestation to be running to work. No Basestation and AD Lite won't run.
APO1972
I m sorry, what do you mean? Usb dongle feed the targets throught modesmixer2 to Basestation and looks like that the. sqb database is working.
AD Lite checks if there is a running version of the BaseStation.exe .
APO1972
Yes the Basestation is running all the time, dongle is feeding as i said with data throught modesmixer2
Does ADLite work if VRS isn't running?
APO1972
Nope i've test it... I think the problem began and its due to USB dongle and all the setup... Before with SBS-1 run perfect
If all you changed was the receiver from SBS to DVB-T "dongle", that should not be the issue.
APO1972
Its first time i m running usb dongle and AD Lite together, because i d like my aircraft database to be always up to date.
What I'm trying to say is if ADLite worked OK before with your setup using an SBS-1, just swapping it for a DVB-T should not cause ADLite to error.
Finally finished decorating lounge with associated moving of furniture. And with new carpet fitted today I should have some time to test a dongle with BS, VRS, etc. to see what the problem is. If I can find anything.
