September 23, 2026, 08:49:37 PM
FD 7.9
Started by charliebrown, April 04, 2012, 03:57:16 PM
charliebrown
Over the last week I have started getting an error message from FD 7.9. I've attached the error message below.
I have an SBS 1er (ver168), PP, FD7.9 and Active Display Lite.
I have tried re-installing FD 7.9 but this had made no difference.
Any suggestions how to sort out this problem.
Charlie
If you view the InternetErrors, txt file I suspect it's a problem with DaveReid's FRL routes server.
I have emailed him but not had a reply.
charliebrown
Hi Mike
Where would I find the InternetErrors.txt file ?
Charlie
In the UserData sub-folder in Basestation folder.  Look for a txt file called FD Internat Errors.txt and open with Notepad or any other text editor.
charliebrown
Hi Mike
Found it.
Have attached below.
Not sure what it all means.
Charlie
The key bit is this, which refers to DaveReid's FRL route lookup.
04/04/2012 19:19:20 - Errorcount=9 - SHT19W - FRL - Client found response content type of 'text/html', but expected 'text/xml'.
The request failed with the error message:
I'd disable FRL from the lookup sites that FD uses.
charliebrown
Quote from: Anmer on April 05, 2012, 07:03:12 PM
How do I go about that Mike.
Charlie
There's an online User Guide for FD.
Options (1)
Bottom of the tab window.
Second one along.
Set FRL Service to "0"
charliebrown
charliebrown
Hi Mike
That seems to have fixed the problem with FD 7.9.
Charlie
Great, thanks for the update.
DaveReid has now fixed the FRL route lookup and I've tested it OK with Flight Display.
charliebrown
Thanks for that Mike.
I will enable it again in FD 7.9.
Charlie
