September 04, 2026, 05:19:58 AM
ModeSDeco2 / ModeSMixer2 on a separate PC, any drawbacks?
Started by larsras, May 09, 2015, 08:47:58 PM
larsras
Planning to have those 2 apps running on a separate PC, and the do all the viewing on my normal PC.
Are there some apps (those that i use now + evt. PlanePlotter) that will not work over LAN?
br Lars
Hi Lars,
I am sure there are some programs that won't work over a LAN, but the ones I use all do.
In case you are not sure how to set things up, have a look at the notes I wrote here for setting up these two programs:
http://radarspotting.com/forum/index.php/topic,2978.msg24218.html#msg24218
All you should need to do to view the output of ModeSDeco2 is replace 127.0.0.1:8080 with the correct IP address of the computer running that program into a browser window on your 'normal PC' and that should give you the graphical output from MD2. e.g. 192.168.1.100:8080. I have not tried it so if it doesn't work use the same feature in ModeSMixer2 but remember to add the --web 8080 switch into the command line
If you want to use BaseStation to view the output, then that's also straightforward, again see my notes but change the 127.0.0.1. setting in BS to the local LAN address of the computer running ModeSMixer.
