May 26, 2026, 10:56:53 AM
Windows 10
Started by Jacobite9428, August 17, 2015, 11:29:56 AM
Jacobite9428
Hi, are there any members using Windows 10 OS with RadarBox? If si have you had any issues.
Reading the AirNav forum, you may have issues, depending on which Windows version you upgrade from and the folder location was used for the original RadarBox software install.
Jacobite9428
Quote from: Anmer on August 17, 2015, 12:37:36 PM
Thanks for your reply, I will be upgrading from windows 7 but I do not want to have an issue regarding drivers etc.
birdie
Quote from: Jacobite9428 on August 18, 2015, 12:44:34 PM
RadarBox works better ( without any issues ) as a Door stopper.
in Window 7 - it crashed whenever other software program is closed.
tarbat
Quote from: Jacobite9428 on August 17, 2015, 11:29:56 AM
I had no issues moving from Windows 8.1 to Windows 10.
Quote from: tarbat on September 14, 2015, 01:26:20 PM
Was your Win 8 RadarBox install in the default folder location?
tarbat
No.  I've always recommended installing outside the default location to avoid all the Virtual Store complications.  SO, installed in C:\MyProgs\AirNav Systems\AirNav RadarBox
Thanks, I thought you would have done that.
