May 19, 2026, 07:22:29 PM
Brussels Airlines - OO-SNA
Started by KeithH, September 02, 2015, 06:22:20 PM
KeithH
Anyone know why the above never appears to plot on the SBS screen?  It shows on FR24 and doesn't show there as MLAT but my SBS has never shown the plot although all other aircraft do plot.
Keith
What is the hex code that FR24 shows?
Truetrack
well within 2nd half of August OO-SNA A320 44CDC1 intermittantly was not showing full ADSB
just ALT readings, regardless whether flying for/under BEL or TCW c/s,
and often not a complete days ops.
Seems to be at random off/on , either deliberately switched or intermittant malfunction.
Klaus
Was FR24 showing the same hex code for the ADS-B position?
Truetrack
@ Mike
I retrieved this from BS Reporter
myself cannot tell
I am using FR24 Tracker seldom and then only using the Flt-No as key for lookup of a possible reg
which I otherwise could not retrieve.
Klaus
If you see the flight on FR24 again, check the hex code as well as the displayed registration.  Also make a note of the flight ID and UTC time (for playback)  The FR24 database may be incorrect.
KeithH
Quote from: Anmer on September 03, 2015, 03:52:49 PM
When I saw it yesterday it was showing 44CDC1 on FR24 and on my own Basestation.  My database shows it as this REG/HEX as does Airframes.org.  FR24 was showing it on the map with no MLAT status.  On my Basestation it was showing with just the green circle (ie not plotting).  Each time it has been in MAN that I'm aware of it has never plotted.  These have all been on Brussels flights.  It was operating the BEL35K out of MAN yesterday evening (18:10 BST).  Strange"
HTH
Keith
Thanks Keith.
Did you notice what radar code was displayed by FR24?
KeithH
Quote from: Anmer on September 03, 2015, 04:29:20 PM
Thanks Keith.
I've just been watching the FR24 and it shows as T-EGGP49 until it was over Stafford then it changed to "MLAT", then shortly after to T-EGNC4, then T-EGSS27 over Luton/London.
Keith
Thanks Keith
Maybe someone is feeding FR24 with "private" MLAT plots using the feeder utility that FR24 thinks are ADS-B messages?
There's now a plethora of closed user MLAT groups and ways to rehash data.
KeithH
Quote from: Anmer on September 03, 2015, 05:26:04 PM
Thanks Keith
Thanks, at least it allowed me to find OO-SNA in the sky as my SBS didn't give me a clue as to where it was except height.
Keith
