November 23, 2026, 04:42:44 AM
Trying to get this working with an SBS-1e
Started by Wrongway, October 13, 2015, 01:50:45 PM
Great.  Thanks for your invaluable input Ian.
I've got VRS already set up for testing output from modesmixer and modesdeco so it was easy to try things.
Wrongway
Ian,
is there an idiots guide to modesmixer and modesdeco.  I tried the website but found it a bit hard going and there doesn't seem to be any youtube videos either.
Quote from: Wrongway on October 13, 2015, 06:03:31 PM
I couldn't find one so I've put it high up on my To Do List
gabuliatko
#19
Is true way SBS-1 -> Multi-EM -> ModeSMixer? If yes, what switch in ModeSMixer do I use?
What do you want to do with modes2mixer?
It is usually used to connect a receiver (e.g. dongle. SBS-1, etc) to a display program such as VRS, GlobeSRTL
gabuliatko
I have old (first) SBS-1. It works only with MultiEM (from jetvisio.de) or directly through the USB cable.
I'd mode-S data from SBS-1 combined with Mlat data from RaspberryPi with RTL-SDR and and view them in BaseStation.
Why are you using Multi-EM?
"Multi-EM
The Multi-EM is a software add-on to enable multiple BaseStation sessions to a single, Ethernet enabled SBS-1. It is available from www.jetvision.de and is similar to the SBSnet Pro software that is used with the SBSnet device."
If you have an SBS-1 you do not have an Ethernet port unless you have the retrofit Ethernet module.
You can connect to an Ethernet enabled SBS-1 without using Multi-EM.
gabuliatko
I have SBS-1 with SBSnet device (http://jetvision.de/sbs/sbsnet/sbsnetflyer.pdf)
I thought that MultiEM is a newer version SBSnet with identical features.
ModeSmixer works identical with MultiEM or SBSnetPro. Connect, but no data.
Zdenek
PS: My idea is split data, modes from SBS-1 and Mlat from RasPi with RTL-SDR, to Basestation.
If you know how , I'll be happy for the advice.
Multi-EM is a utility to run more than one BaseStation session using just one SBS-1 receiver.
Multi-EM is similar to SBSnet Pro but not necessary if you don not intend to run multiple BaseStation sessions.
Can you post a screenshot of your Multi_EM or SBSnet Pro "Network" tab showing the IP and Port settings?
Trying to use both SBSNet and MultiEM is confusing the issue.
Just test without starting MultiEM.
ModeSMixer should connect with the command line:
modesmixer2.exe --inConnect <IP address of SBS-1>:20060
If it connects, it will tell you it is connected.
If it does not:
  • what is the IP address of the SBS-1?
  • what is the IP address of your PC?
  • post the command line you are using for modesmixer
Once that bit is working,we can see how to join the data from the SBS-1 and the Raspberry Pi
gabuliatko
quote IanH
IanH: great job, thank you. I'm sorry it occurred to me , thank you.
Zdenek
