November 24, 2026, 07:35:27 PM
sbs 3 usb cable
Started by mcfcmike64, December 02, 2015, 10:48:56 PM
mcfcmike64
does anybody know where i can get a usb cable for my sbs 3
http://www.tmrf.co.uk
Ring Chris Taylor, he will sort you out.
Or Amazon, eBay, Maplins etc.
There's nothing unique about the SBS-3 USB cable.
acarslogger
QuoteThere's nothing unique about the SBS-3 USB cable.
If you intend to run the SBS-3 SDRs you may need a special Y cable USB.
See Basestation Reference Manual section 2.1.
Stuart
#4
Yes that's what I thought.
Something like this?
http://www.ebay.co.uk/itm/High-Speed-Double-USB-2-0-A-to-Mini-5Pin-Male-Extension-Y-Cable-Clear-2-3Ft-/391158083671
I think the SBS-3 connector is a mini USB and NOT the micro USB which are more common now. Mine's in the loft so can't check easily.
Edit: seems my suspicions are correct http://www.kinetic.co.uk/forums/viewtopic.php?f=9&t=14574&start=90
Quote from: acarslogger on December 03, 2015, 11:01:18 AM
But it's not unique to the SBS-3.
And Yes IanH, the SBS-3 connector is a Mini-B.
http://www.usbcables.com/usb-connectors
acarslogger
It may not be unique to the SBS-3, but all I was trying to emphasise was that the USB cable required may not be a bog-standard USB cable with 1 plug at each end; a point not made clear in the earlier post.
I hope my input helped to assist the user, but if people are going to get petty about detailed definitions, I won't bother in future.
Stuart
Quote from: acarslogger on December 03, 2015, 12:38:08 PM
Your input was helpful, as always.  I was only trying to point out that the cable isn't unique to the SBS-3 and can be sourced from suppliers other than TMRF.
You replied quoting mine about it not being unique and I was clarifying the point.  Some may call it "petty", I prefer "precise".   ;)
