September 23, 2026, 04:40:35 PM
modemixer2 filtering airplanes
Started by herrmann-s, December 09, 2015, 08:20:17 PM
herrmann-s
hi,
is there any possibility to add some sort of filter to filter "uninteresting" hex ranges out or show ONLY INTERESTED hex range?
for example
a positive filter and negative. lets say i m interested in german airplanes only then i can add "pass only hex-range 4C0000 - 4CFFFF"
and negative filter if i am NOT interested in german airplanes "dont let them pass from hex-range 4C0000 - 4CFFFF"?
and also which accepts "and"
a very nice solution would be to read some sort of text file which looks similar to condex.txt file of planeplotter. that would bereally great.
i can reduce the traffic a little bit and shows only airplanes i am interested in.
suggest you put this in the "Features suggestion" thread - might get ignored otherwise
http://radarspotting.com/forum/index.php/topic,5589.0.html
herrmann-s
