August 24, 2026, 09:14:28 AM
Refresh Problem?
Started by KeithH, February 16, 2016, 02:15:49 PM
KeithH
I have a refresh problem that I can't seem to find the answer to.
I'm sure this is a new problem. I haven't changed anything or installed anything recently.
I run a Puck with Basestation 1.2.4.184 and use the PlaneBase database to populate the database with new contacts.
When a "new" aircraft is detected the Basestation shows a blank line in the aircraft list save for the Status, State and Altitude columns.  PlaneBase sees the new record and updates the SQB.  But the new data doesn't show in Basestation unless I hit F5.
I have been through all the Settings in Basestation and looked through the INI file but cannot find anything that would force a timed refresh of the screen.
The database is definitely updated because I can see the update using SQLite.
I could just keep pressing F5 but I'm sure this was not a problem before I noticed it recently.  Am I missing something??
PS I'm running Windows 10.
I'm pretty sure there's no auto-refresh option in BaseStation.  Is there one in PlaneBase?
Are you sure it was refreshing previously?
KeithH
Quote from: Anmer on February 16, 2016, 02:48:38 PM
Hi, thanks for the reply.
Yes, there is a refresh option in PlaneBase.  Two in fact a manual button and an automatic option.  I was pretty sure I hadn't updated or installed anything that would effect this.  So thought the problem was within Basestation.  I can select the "Aircraft Details" window and update from there and all works well and the data seems to be refreshed by Basestation that way.  I'll go down the Planebase option and have a look see there.
Thanks again.
