April 25, 2026, 03:01:29 AM
The New FlightRadar24
Started by Anmer, March 17, 2016, 02:00:36 PM
w4lron
I still don't see N feeds data and fall as uptime statistics
Using SBS-1, Fr24Box, Puck1090
Quote from: w4lron on March 29, 2016, 07:55:17 PM
I emailed FR24 about N-feeds at the weekend.  The person who handles it is away on vacation but he said he'd ask Stockholm to check.
w4lron
Quote from: Anmer on March 29, 2016, 07:59:29 PM
thanks for reply  8)
terrywadeairbus
Hi Anmer
Further to my problem not being able to receive premier subscription to FR24, I've just received this
email from FR24 support:
The Business subscription will remain active as long as you are sharing data with Flightradar24. If you stop sharing data, your subscription will be downgraded to Gold after 48 hours. If we have not received data from you for 7 days, your subscription level will return to Basic.
Could you please check if your receiver is connected and working properly.
I hope this helps, but please let me know if you need anything else or if you have any other questions.
And you are N-EGKB1.
Thank you for supporting FR24!
Is there anyway that with the new FR24 upgrade that I might not be feeding FR24 anymore? Is there a way of checking other then checking on individual flight on the FR24 screen? I haven't changed any settings with my BS or SBS1 Client?
Terry
Hi Terry
There appears to be a problem with SBS1 Client feeds which I have previously reported.
But earlier you said "FR24 is showing my feed F-EGKB1 on some aircraft"  "F" is not the same as "N".
Go back to FR24 Support and tell them to check if the "N" feeds are being recognised for Premium subs and mention that I have already reported this to Piotr.
terrywadeairbus
Hi Anmer
Sorry I think I've confused things my feed has always been   N-EGKB1, not sure where the F came from?
So I take it anyone using the SBS1  client feed has only a basic subscription right now?
I will get back to FR24 and pass on what you've said.
Is there a way I can bypass the client for now and get premier subscription with FR24 until the issue
with the client is fixed?
Terry
Harold Brown
Hi Terry,
I am having exactly the problem as yourself. Since the upgrade my subscription status shows as Basic even though I am 24/7 feeder via the MMS2 Network (EGGW1).
Despite several emails to FR24 in order to resolve the issue I have yet to receive an explanation or indeed a reply apart from an automated response stating I have been upgraded to Business (even though I haven't!).
Very poor!, I feel like withdrawing my data feed as a protest.
Harold Brown
Quote from: terrywadeairbus on March 30, 2016, 03:24:03 PM
That may be the current situation.  I reported it at the weekend but no one at FR24 has confirmed or otherwise.
You sure can, use any of the alternative feeding options that are available.
Quote from: Harold Brown on March 30, 2016, 03:25:53 PM
Hi Terry,
That's your choice.  But I don't think it will make much difference.  MMS2 feeds are not as valuable to FR24 as they were in the beginning.
Success breeds...........
terrywadeairbus
Thanks for the replies.
I've now made another error.
I thought it might be worth upgrading to a newer version of the FR24 feed. Now when I go
to FR24 it shows a yellow explanation mark saying a new software update is available, and I'm really not sure where to start to upgrade or get my old feed software back?
Terry
You'll have to use the latest feed version.
terrywadeairbus
Hi Anmer
I've downloaded the latest FR24 feed software from their website.
I assume the error message below is because the issue with the MMS Client issue.
When I went through the set up it ask me for port settings non of which were the same as the client
ones so I selected no to ports?
Terry
How are you connecting to your SBS - USB or Ethernet?
terrywadeairbus
Hi Anmer
I'm connecting via a USB cable.
I'm now just using the local mode of the MMS Client and using my old FR24 feed program and my
FR24 subscription has changed to business membership!
I would still like to use the Client, so will that be possible when FR24 have sorted the issue with
N feeds? I'm now showing as T-EGKB35 and the N feed is showing as inactive.
Thanks for your help
Terry
