October 23, 2026, 01:40:15 PM
puck1090 cutting signal issue
Started by w4lron, March 30, 2016, 04:14:45 PM
w4lron
hi all
I'm having an interesting problem.I'm using kinetic puck 1090 + omni vertical 5db antenna 10m cable.
Marked point receiver position, the signal is lost in the cutting marks.
I don't have problems with different receiver. :(
Do you have any idea?Thanks.
Using SBS-1, Fr24Box, Puck1090
Do you have a different antenna you could try with the Puck?
w4lron
Quote from: Anmer on March 30, 2016, 04:18:29 PM
Yes, I tried it
I tried to fr24box antenna.The result is still the same  :'(
What make/model s the other receiver and do you us RS for the comparison?
w4lron
Quote from: Anmer on March 30, 2016, 06:04:10 PM
Other receiver Fr24box no problem!
I tried both at the same point
I did the test with DVB-T in the same area no pronlem!
Puck lives cut in the top flight
Quote from: w4lron on March 30, 2016, 06:08:48 PM
What did you use to view the local traffic from the FR24 Radarcape?
w4lron
Quote from: Anmer on March 30, 2016, 06:50:43 PM
I watch the local traffic with ADSBScope
Quote from: w4lron on March 30, 2016, 07:05:13 PM
Thanks.  I thought your screen capture was Virtual Radar Server?
I can remember ADSBScope had some decoding issues.
Can you try each receiver using VRS?
w4lron
Quote from: Anmer on March 30, 2016, 07:13:42 PM
Now i try it
Indeed, the fundamental data coming out of the basestation 30006
When the signal is lost in the base station program logo is changing, loss passes to the signal logo
Do you have a Puck and SBS-1?
If you do, using BaseStation, do you lose the data reception when using each receiver and the same FR24 antenna?
w4lron
#10
Quote from: Anmer on March 30, 2016, 07:49:58 PM
No no I'm using SBS-1 a different location and has no connection with it.
I can use puck it in this way.I Add picture.The following link address (removed by Mod)  (puck1090+modesmixer)(link to delete after you see)
Does the aircraft track disappear in BaseStation connected to the Puck without using ModeMixer?
I have seen no other reports of a Puck causing a signal gap.  There are many reports of antennae doing this but not a receiver.
w4lron
Quote from: Anmer on March 30, 2016, 08:14:39 PM
I'm about to eat because of this problem head  ;D I guess, I try and buy a new antenna required
puck connected to pc via USB --> using basestation (It does not work otherwise) --> ModeSmixer2(connected bs 30006)
