September 22, 2026, 07:39:25 AM
Hi all
Started by micked, April 08, 2016, 09:50:53 AM
micked
Hi all, I´m 43 years old , live in sweden and have done adsb tracking for about 3 years, feeding to fr24 and adsbexchange, my set up is a slighly modified rtl t2 stick, it got sma connector, heatsinks on tuner and rtl chip, microfan, lna power and some decoupling caps, also fitted a low ppm smd crystall for better stability, antenna is a j-pole with a tv-lna mounted and fed through about 23m o f tv-coax cable, usuly se about 700-800 planes a day with about 150 000 hits/day, next mod to the rtl will be a shielded inductor for the switching ldo.
/Mikael
Welcome Mikael and thanks or explaining your setup.
