April 24, 2026, 07:15:47 PM
Outlines
Started by gcopter1, April 12, 2016, 07:28:47 PM
gcopter1
I recently installed PP and I'm trying to configure the display to resemble the look I have in Basestation.
I copied all the .out files I had in BS and transferred them over to PP. So far so good.
I clicked on select all and hit ok. Found some unwanted clutter that I want to get rid of, but, since I'm not familiar yet with what is what, I started to deselect and hit ok in hopes of finding the correct outline that is loading  and cluttering my display. However, it seems as if PP has a mind of its own and just loads everything. Is there other setting I should be looking for?
Or, is PP taking its sweet time on account that it's hogging resources and delaying the results I'm seeking?
The clutter in question looks like a lot of straight lines going in different direction, don't know what are these called and if anyone has a clue what I'm talking about, please drop a hint.
From memory, PP loads all the outlines in the referenced folder.  But I don't use PP much so could be wrong.  I'm sure someone else will comment more knowledgeably.
Can you post a screenshot of what you see?
#2
QuotePP loads all the outlines in the referenced folder
I assumed that too but found that under Option/Chart/Outline there is an option to "Select Outline files to Plot".
But selecting "All" or "None" doesn't seem to have any effect - even tried restarting PP so looks like we need help here  ;).
I'm wrong. Selected just one to show, restarted PP and that worked, Selected "All", restarted PP and they were back.
gcopter1
Where do the waypoints, .wpt files go?
Breitling
I have them on the chart files folder, then you have to select them on "options...chart...GPX overlay"
gcopter1
gcopter1
Quote from: Breitling on April 13, 2016, 07:21:07 AM
Hmm, tried that, no dice.
Don't they have to have .gpx in order to be usable?
