November 16, 2026, 10:11:08 PM
1090 mhz antenna in same mast tv antenna
Started by mt007, April 18, 2016, 03:11:17 PM
mt007
Hi guys,
there exist any problem if i put my adsb antenna in same tv antenna mast?
Exist any interference?
Miguel Teixeira
Beast user, Ex: SBS1er and RB, PP sharer aH Live Traffic
There shouldn't be any interference but you may want to place the Mode-S antenna away from any other ones to avoid any close shielding of signals by the physical antenna..
mt007
Thanks Anmer,
But i only have one mast and is very dificult put another but will see.
Is possible conect to adsb antena one cable with can catch adsb, airband and possible ais and using a splitter?
Maybe conect a pre-amplifier too.
Regards.
Miguel Teixeira
You can attach the Mode-S antenna to the existing mast.  Possibly set it away from the other antenna, as I have:
http://radarspotting.com/forum/index.php/topic,5421.msg25909.html#msg25909
What antenna will you use to cover Mode-S, Airband and AIS reception?
mt007
Miguel Teixeira
Quote from: mt007 on April 18, 2016, 05:05:37 PM
I have a wimo 1090mhz antenna.
Thanks.  I don't think that one will receive Airband or AIS signals.
edgy
#6
Hmm... images no worky. Oh well...
Quote from: edgy on April 18, 2016, 05:15:09 PM
Images do work.  How are you trying to post one?
Here's an example using img and the location link.
[img]http://www.kinetic.co.uk/Trilby_gallery_files/master_21466.jpg[/img]
mt007
Anmer,
How you pass cables inside house?
Miguel Teixeira
Quote from: mt007 on April 18, 2016, 06:52:08 PM
I drilled a hole through the wall.  Before I put the 10mm Ecoflex under a roof tile.  It depends on thickness of the cable and what options you have locally.
edgy
I was using google drive. They won't let you just link, you have to get a google+ account. I'll pass :-)
Quote from: edgy on April 19, 2016, 03:24:52 AM
You should be able to get a shareable link:
https://drive.google.com/open?id=1xNWmSwJyeHYKEQXMnf64TNw51mOpL14tiQ
And with a little bit of manipulation and Thanks to:
http://googlesystem.blogspot.co.uk/2013/02/permalinks-for-google-drive-images.html
Breitling
Hi Miguel, you can use a double arm support attached to your mast. That's how I have antennas, anemometers, etc (I'll take a pic of the real thing).
Or you can use a single wide-band discone type antenna to cover all the frecuency range you want. Anyway it will always be better to have specific tuned antennas.
mt007
Miguel Teixeira
