October 28, 2026, 05:09:29 AM
Aircraft list stopped working
Started by gcopter1, April 22, 2016, 07:01:46 PM
gcopter1
Everything else works fine, except when I click on "Expand All Aircraft List"
Used to work fine before but now I get an error reporting window containing the error ready to be sent to Kinetic support.
Below you will find the error copied to the clipboard and pasted here. My apologies for the lengthy message.
App: BaseStation
Version: 1.2.4.185
Occurred : 13:53:57.483 2016/04/22
Error : EAccessViolation - Access violation at address 0053B740 in module 'BaseStation.exe'. Read of address 00000008
Last Command : UPDATE Flights SET EndTime = '2016-04-22 13:48:21.696', NumPosMsgRec = 109, NumADSBMsgRec = 309, NumModeSMsgRec = 0, NumIDMsgRec = 12, NumSurPosMsgRec = 0, NumAirPosMsgRec = 109, NumAirVelMsgRec = 111, NumSurAltMsgRec = 0, NumSurIDMsgRec = 0, NumAirToAirMsgRec = 0, NumAirCallRepMsgRec = 0, HadAlert = 0, HadEmergency = 0, HadSPI = 0, UserNotes = '', FirstIsOnGround = 0, LastIsOnGround = 0, FirstLat = 24.46469, LastLat = 24.23603, FirstLon = -81.98200, LastLon = -82.51069, FirstGroundSpeed = 398.0, LastGroundSpeed = 395.7, FirstAltitude = 35975, LastAltitude = 36025, FirstVerticalRate = 0, LastVerticalRate = 0, FirstTrack = 246.1, LastTrack = 245.8 WHERE FlightID = 30805
Last Aircraft : AD2BAA
System Status : 28508160 | 0 | 28508160 | 25020744 | 1229028 | 3.7.11 | 14503137280
Previous : O-WriteToDebugMemo | I-WriteToDebugMemo | O-ActionExpandedAllAircraftListExecute | O-HandleAircraftListExpandedStatus | I-HandleAircraftListExpandedStatus | I-ActionExpandedAllAircraftListExecute | O-ProcessPacket | I-ProcessPacket | O-ProcessPacket | I-ProcessPacket | O-ProcessPacket | O-ProcessADSBMessage | I-ProcessADSBMessage | I-ProcessPacket | O-ProcessPacket | I-ProcessPacket | O-ProcessPacket | I-ProcessModeSMessage | I-ProcessPacket | O-ProcessPacket | I-ProcessPacket | O-ProcessPacket | I-ProcessPacket | O-ProcessPacket | I-ProcessPacket | O-ProcessPacket | I-ProcessPacket | O-ProcessPacket | I-ProcessPacket | O-ProcessPacket
Occurred : 13:53:58.247 2016/04/22
Previous : O-WriteToDebugMemo | I-WriteToDebugMemo | O-MainSecondTimerTimer | O-GeneralConnectionTimer | I-GeneralConnectionTimer | O-RadioMenuCheckingTimer | I-RadioMenuCheckingTimer | O-VersionInfoCheckingTimer | I-VersionInfoCheckingTimer | O-StatusBarTimer | I-StatusBarTimer | O-ProvisionalAircraftListTimer | I-ProvisionalAircraftListTimer | O-AircraftListTimer | I-AircraftListTimer | O-AircraftListGridTimer | O-AircraftListGrid.UpdateValues | G-AircraftListTimer-Updating | O-HandleOnSelectedAircraftChanged | I-HandleOnSelectedAircraftChanged | G-AircraftListTimer-Sorting | I-AircraftListGrid.UpdateValues | I-AircraftListGridTimer | O-RedrawTimer | I-RedrawTimer | O-DisplayTrackingTimer | I-DisplayTrackingTimer | O-AircraftTimer | O-DispatchDelayedMessages | I-DispatchDelayedMessages
Occurred : 13:54:04.057 2016/04/22
Last Command : UPDATE Flights SET EndTime = '2016-04-22 13:48:28.791', NumPosMsgRec = 304, NumADSBMsgRec = 739, NumModeSMsgRec = 0, NumIDMsgRec = 32, NumSurPosMsgRec = 0, NumAirPosMsgRec = 304, NumAirVelMsgRec = 317, NumSurAltMsgRec = 0, NumSurIDMsgRec = 0, NumAirToAirMsgRec = 0, NumAirCallRepMsgRec = 0, HadAlert = 0, HadEmergency = 0, HadSPI = 0, UserNotes = '', FirstIsOnGround = 0, LastIsOnGround = 0, FirstLat = 26.79272, LastLat = 27.05234, FirstLon = -80.29083, LastLon = -80.30182, FirstGroundSpeed = 193.6, LastGroundSpeed = 189.6, FirstAltitude = 6400, LastAltitude = 6400, FirstVerticalRate = 0, LastVerticalRate = 0, FirstTrack = 352.6, LastTrack = 337.4 WHERE FlightID = 30811
Last Aircraft : A622BE
Occurred : 13:54:04.992 2016/04/22
System Status : 29818880 | 0 | 29818880 | 25218952 | 2332100 | 3.7.11 | 14503137280
Occurred : 13:54:07.026 2016/04/22
Occurred : 13:54:10.028 2016/04/22
Occurred : 13:54:13.074 2016/04/22
Last Command : UPDATE Flights SET Callsign = 'NKS936' WHERE FlightID = 30873
Last Aircraft : A7FED0
Occurred : 13:54:18.194 2016/04/22
Last Command : UPDATE Flights SET EndTime = '2016-04-22 13:48:43.874', NumPosMsgRec = 446, NumADSBMsgRec = 924, NumModeSMsgRec = 0, NumIDMsgRec = 46, NumSurPosMsgRec = 0, NumAirPosMsgRec = 446, NumAirVelMsgRec = 431, NumSurAltMsgRec = 0, NumSurIDMsgRec = 0, NumAirToAirMsgRec = 0, NumAirCallRepMsgRec = 0, HadAlert = 0, HadEmergency = 0, HadSPI = 0, UserNotes = '', FirstIsOnGround = 0, LastIsOnGround = 0, FirstLat = 25.83636, LastLat = 25.80263, FirstLon = -80.61182, LastLon = -80.30940, FirstGroundSpeed = 257.3, LastGroundSpeed = 124.1, FirstAltitude = 2875, LastAltitude = 125, FirstVerticalRate = 0, LastVerticalRate = -832, FirstTrack = 100.5, LastTrack = 88.2 WHERE FlightID = 30818
Last Aircraft : A34FAE
Occurred : 13:54:21.222 2016/04/22
Last Command : INSERT INTO Flights(SessionID, AircraftID, StartTime, Callsign) VALUES (110, 6012, '2016-04-22 13:54:20.199', '')
Last Aircraft : AAF800
Occurred : 13:54:22.281 2016/04/22
gcopter1
...and found out what it was.
In the beginning of installing BS, I wanted to maximize screen real estate by doing away with the aircraft list. I discovered that by un ticking columns I could eliminate the info displayed and using the close button, no more aircraft list.
Later on, I wanted to launch aircraft list and, the error above posted, came to be. Reversed my steps regarding the un ticking of columns and now it is running again. :-[
