May 19, 2026, 01:45:29 PM
new CityJet Sukhoi
Started by KeithH, July 01, 2016, 08:54:20 AM
KeithH
I wasn't sure where to put this question so here goes.
I have noticed that the new Superjet flown by CityJet do not plot on my Basestation.  FR24 appears to rely on MLAT to show it.
I thought all new aircraft had to have full SBS.  Or have CityJet elected to turn it off?
Anyone know the reason please?
Keith
Possibly not using ADS-B.
What's the registration or hex code?
Edit,  EI-FWA 4CA6C5.
KeithH
Quote from: Anmer on July 01, 2016, 09:13:25 AM
Yep, that's the one!  I think that's the only one they have at the moment.
KeithH
Wasn't there a change in that all new aircraft above a certain weight had to have full ADS-B.  All ATR's now have it (I believe).
Not sure if this is the current position?
Eurocontrol:
For Aircraft with a Civilian Registration:
Aircraft operating IFR/GAT in Europe are required to carry and operate Mode S Level 2s (i.e. with SI code capability) transponder(s) with Mode S Elementary Surveillance (ELS) capability. The applicability dates for this requirement is:
    8 January 2015 for "new" aircraft, i.e. aircraft with an individual certificate of airworthiness first issued on or after 8 January 2015
    7 December 2017 for aircraft with an individual certificate of airworthiness first issued before 8 January 2015
Aircraft operating IFR/GAT in Europe and with a maximum certified take-off mass exceeding 5 700 kg or having a maximum cruising true airspeed capability greater than 250 knots are required to carry and operate Mode S Level 2s transponder(s) with Mode S Elementary Surveillance (ELS), Enhanced Surveillance (EHS) (for fixed wing aircraft) and ADS-B 1090MHZ Extended Squitter (ES) capabilities. The applicability dates for this requirement is:
    8 June 2016 for "new" aircraft, i.e. aircraft with an individual certificate of airworthiness first issued on or after 8 June 2016
    7 June 2020 for aircraft with an individual certificate of airworthiness first issued before 8 June 2016
Note that aircraft operating under a civilian registration that do not meet specific criteria may be granted an exemption against the Mode S EHS requirements.
For State Registered Aircraft:
All State aircraft operating IFR/GAT in Europe are required to carry and operate Mode S Level 2s transponder(s) with Mode S Elementary Surveillance (ELS) capability by 7th December 2017.
    Member States shall communicate and justify to the European Commission a list of State aircraft that cannot be equipped with ELS in due time before 1 July 2016.
All fixed wing transport-type State aircraft operating IFR/GAT in Europe and with a maximum certified take-off mass exceeding 5 700 kg or having a maximum cruising true airspeed capability greater than 250 knots are required to carry and operate Mode S Level 2s transponder(s) with Mode S Elementary Surveillance (ELS), Enhanced Surveillance (EHS) and ADS-B 1090MHz Extended Squitter (ES) capabilities by 7 June 2020.
    The equivalent deadline for the communication of a list and justification of State aircraft that cannot be equipped in due time with EHS and ADS-B is 1 July 2018.
Rationale behind the above justifications may be compelling technical reasons, procurement constraints and State aircraft going out of service before 1 January 2020. In case of procurement constraints Member states' justification shall include the pertinent procurement plans.
http://www.eurocontrol.int/spi-ir
KeithH
Quote from: Anmer on July 01, 2016, 09:38:49 AM
Eurocontrol:
Thanks Anmer!  Not sure what the weights are of the SuperJet (must look it up).
#6
Well it certainly weighs more than 5.7 tonnes (45.8 tonnes MTOW - according to Wikipedia) and cruises at 448 knots.
I guess it falls into the 7th June 2020 category as it probably had an airworthiness cert issued before 8th June - delivered 2nd June according to PB.
KeithH
Quote from: Anmer on July 01, 2016, 05:43:01 PM
Well, the latest delivery has ADS-B:
http://radarspotting.com/forum/index.php/topic,6178.msg30333.html#msg30333
Yes, just noticed the latest one does plot.  I assume the next ones will too.
