April 30, 2026, 07:22:48 AM
SBS-1 + Raspberry pi?
Started by skywatch, August 16, 2016, 04:41:01 PM
skywatch
OK, so I have had a SBS-1 with network port for over 8 years and it's been a lot of fun. But now I have some raspberry pi boards looking for a new challenge..... So, what, if anything, can I do with them and the SBS-1 ?
Could I, for example, have the pi populate a basestation database on a server that is also shared with the laptop so both have access and the pi will record a/c when the laptop is off/away?
Can I use it to share data to the web? How?
Any other ideas?
I'm sure you can "drive" the BaseStation.sqb using a RPi/DVB-T combo via ModeSMixer.  But I'll let those more experienced confirm or otherwise.
As for "sharing" the sqb file, I'm not aware that you can have more than database "client" but I'm sure I'll be corrected.
I think you can use Virtual Radar Server to "publish" your data to the web.
