November 23, 2026, 12:31:58 PM
operator flag capacity
Started by hispeedbypass, September 07, 2016, 06:49:11 PM
hispeedbypass
Could anyone tell me if there is a limit to the number of operator flags Basestation can manage from the OperatorFlag folder?
I hit a problem when i exceeded 9458 flags and tried to add further 200 or so.
The result was BS froze on screen and only a forced closure enabled my PC to restart.
I'm using Windows 7 Professional 64bit and capacity on HDD is more than enough.
I did think it might be possible (in theory) that any flags specific to an aircraft (i.e. Registration etc) would be able to be included along with any new or amended airlines.
The fact that basestation reporter can allow in excess of 100K registrations seems to be at odds with what i seemed to now have that somehow the OPS.Flags are limited. Any suggestions?
Oldenglish1
HI I HAD THE SAME PROBLEM I HAD TO DELETE ONE I DINT REQUIRE
REGARDS JEFF
menhams-j
HIS IS TO THE PERSON THAT HAS TOO MANY FLAGS I ONLY HAVE  7500 LOGO'S I HAD 10,OOO LOGO'S AND IT KEPT ON FREEZING WILL NOT EXCEPT MY LIMIT IS 8500 BUT THERE IS ALOT OF LOGO'S AND AIRCRAFT THAT ARE NOT IN USE A FEW PEOPLE USE DIFFERENT LOGO'S 8 OR 9 THOUSAND I HAVE BASESTATION AS WELL JIM
steagles
I have downloaded and unzipped all the logo files into a separate folder and then went thru Basestation reporter and then searched and added the ICAO operator code/flag  that I saw into my Base station folder.
I do this once a week to see what new aircraft have flown past.
( not that many living in North Queensland )  ;D
It works for me to limit the aircraft Logos that I have loaded into Basestation.
Shaun
From what I've seen, there's an unpublished limit to the number of bmp files in the OperatorFlags folder, around 9,000.  Above the limit, BaseStation will freeze when using the Edit feature in the Aircraft Details window.
Personally I only have around 1,500 bmp files in that folder as I keep it relatively simple, either an airline operator logo or aircraft type silhouette.
I suspect Kinetic didn't foresee the abundance of logos depicting specific aircraft.
hispeedbypass
Thank You Gentleman,
So its seems there is to some degree a need to delete then add current flags which based on BS reporter is probably manageable as some file are now obsolete and invariably if an aircraft is moved on to another country's registration the mode s code is changed so Iguess a bit of surgery is now needed. If anyone comes up with a solution to this issue( which I think over time will become more apparent) our forum would be much appreciative of this.
I guess Kinetic have no comment to make or advise to offer!
BS Reporter and the BaseStation database should have no bearing on the number of files in the OperatorFlags folder.
Klaus
Hi there
I experienced the unreported limit of ~9000 files in /OperatorFlags.
BS is running in C:/Kinetic/BaseStation, OS is Windows 7x64 Ultimate.
1. BS was fine with 9288 files in /OperatorFlags until ...
2. I updated the Countried.dat delivered with the BS-CD, with the more updated and detailed one found here: http://woodair.net/SBS/Utilities/Kinetic_Utilities4_Bitmaps.htm
3. BS crashes at start.
3.a. I was changing back to the delivered BS-CD  Countried.dat  and BS is running fine again.
4. I emptied /OperatorFlags completely and try to start BS with the 'new'   Countries.dat  and BS is running fine again.
5. It's time for a close look at my BaseStation.sqb file: it contains 161888 records with OperatorFlagCode set in 29101 records. Only 2908 different OFCs are in use. I wrote a batchfile to copy only the needed OFC files to /OperatorFlags. Just 2372 files were copied, for 536 OFCs i don't have a fitting file.
BS is running fine now with the 'new'  Countries.dat  file and much less files in  /OperatorFlags.
