November 23, 2026, 02:11:53 AM
acarsdeco2 on Win 10
Started by junglejet, September 12, 2016, 04:52:14 PM
junglejet
I have moved an acarsdeco2 folder to a new Win 10 MiniPC (Zotac PI320).
When I start acarsdeco with a USB R820T dongle I get
AcarSDeco2 v.20150718
Using device:  0 already in use
libusb_open error -12
Error: sdr_open(): Bad file descriptor
In the device manager there is a driver activated as a RTL2832 audio/video device. I have deactivated and deinstalled and renamed the driver files (3 files) and rebooted, but still the same message appears and the entry in the device manager is still visible, albeit without driver files.
I issued a --device-list command, but the response is empty.
I was under the impression that drivers are not required for the later acarsdeco2 versions, but something doesn't work here. Can anybody help?
Andy
acarslogger
Hi Andy,
Sorry I can't help with a solution, but I also have exactly the same problem on my W10 machine.
Hopefully someone / Sergsero will assist with a solution.
Stuart
I tried and got exactly the same error, however re-installing the zadig driver has fixed it for me.
I downloaded the driver from http://zadig.akeo.ie/ and followed the instruction here http://www.rtl-sdr.com/getting-the-rtl-sdr-to-work-on-windows-10/.
Might be worth a go.
Keef.
acarslogger
Thanks for the information.
I'll give it a go when I return home to my W10 PC.
Stuart
acarslogger
Hi Keef,
The zadig solution worked. Up and running with AcarsDeco2 on Windows 10.
Stuart
Good to hear you're up and running again  :)
Keef.
I know this is an old topic but it might be relevant again with the Windows 10 April Update landing on machines now.
I've just updated my PC and I had to go through this process again...
Keef.
acarslogger
Hi Keef,
W10 April update arrived here and sure enough acarsdeco2 stopped working. Updated with zadig and now OK.
Thanks for the info.
Stuart
p.s. slightly off-topic but the W10 update also
-- corrupted my Virtual Audio Cables I used between SDRSharp and MultiPSK (for VDL2 and acars decoding). Had to un-install, re-install and reconfigure.
-- PuTTY (used to connect W10 PC to my Raspberry Pis) not working. I can use the W10 SSH. More Googling required.
-- my Network Locations that had been configured to access log file directories on the Raspberry Pi not working.
-- appears to have turned off File History
I wonder what other 'enhancements' I'll find in the new W10.
No response required, although I will raise another topic(s) if required -- just venting my frustration!
