November 22, 2026, 12:07:40 PM
Unable to open database file 14 - Need help, strange Problem!
Started by EDDG, February 15, 2017, 01:08:53 PM
EDDG
i have a strange problem. If i try to start modesdeco2 via script with ' /etc/init.d/modesdeco2.sh start' i get this message:
pi@raspberrypi:~ $ /etc/init.d/modesdeco2.sh start
modesdeco2 started
pi@raspberrypi:~ $ terminate called after throwing an instance of 'BaseStationDbException'
  what():  sqlite3_open \basestation.sqb unable to open database file 14
The script looks like this:
#!/bin/bash
### BEGIN INIT INFO
# Provides:             modesdeco2
# Required-Start:       $remote_fs
# Required-Stop:        $remote_fs
# Default-Start:        2 3 4 5
# Default-Stop:         0 1 6
# Short-Description:    modesdeco2 initscript
### END INIT INFO
## Fill in name of program here.
PROG="modesdeco2"
PROG_PATH="/home/pi/modesdeco2"
PROG_ARGS="--gain 49.6 --freq-correction 58 --location 52.22:7.48 --web 8088 --db \basestation.sqb $
#PROG_ARGS="--interactive --net --net-ro-port 31001"
PIDFILE="/var/run/modesdeco2.pid"
start() {
      if [ -e $PIDFILE ]; then
          ## Program is running, exit with error.
          echo "Error! $PROG is currently running!" 1>&2
          exit 1
      else
          ## Change from /dev/null to something like /var/log/$PROG if you want to save output.
          cd $PROG_PATH
          ./$PROG $PROG_ARGS 2>&1 >/dev/null &
          echo "$PROG started"
          touch $PIDFILE
      fi
stop() {
          ## Program is running, so stop it
         echo "$PROG is running"
         killall $PROG
         rm -f $PIDFILE
         echo "$PROG stopped"
      else
          ## Program is not running, exit with error.
          echo "Error! $PROG not started!" 1>&2
          exit 1
      fi
## Check to see if we are running as root first.
## Found at http://www.cyberciti.biz/tips/shell-root-user-check-script.html
if [ "$(id -u)" != "0" ]; then
      echo "This script must be run as root" 1>&2
      exit 1
fi
case "$1" in
      start)
          start
          exit 0
      stop)
          stop
          exit 0
      reload|restart|force-reload)
          stop
          start
          exit 0
          echo "Usage: $0 {start|stop|reload}" 1>&2
          exit 1
esac
If i try to start via './modesdeco2 --gain 49.6 --freq-correction 58 --location 52.22:7.48 --web 8088 --db \basestation.sqb --silhouettes \silhouettes --google-key xyz' it works perfekt.
I have no idea :(... Can you help me?!
Many thanks.
Best regards,
Peter
A380
Hello,
Try full path to the Database. --db /home/pi/modesdeco2/basestation.sqb
Kind Regards
A380
EDDG
MK2wx
Quote from: EDDG on February 15, 2017, 06:04:30 PM
Thanks A380, i tried it but nothing changes :(...
I suspect the database was perhaps open when copied. That's one thing which I know which could cause it.
Also make sure all permissions are in order.
Lastly, if on a raspberry make sure the owner is pi:pi
I've fallen for all of these across today while getting things going on my PiAware setup. Darned hard to spot some of those were.
Hope some (or even all if you were really unlucky like I was) of this helps.  ;)
evangel
this code works for me.
#!/bin/bash
### BEGIN INIT INFO
# Provides:             modesmixertest
# Short-Description:    modesmixertest initscript
### END INIT INFO
PROG="modesmixertest"
PROG_PATH="/xdeco"
PROG_ARGS="--web 8888 --inConnect 127.0.0.1:30005 --location 45.5:-73.7 --outServer beast:30205 --db /xdeco/bss.sqb &"
PIDFILE="/var/run/modesmixertest.pid"
start() {
          exit 1
      else
          cd $PROG_PATH
          touch $PIDFILE
      fi
stop() {
         killall $PROG
         rm -f $PIDFILE
      else
          exit 1
      fi
      exit 1
fi
case "$1" in
      start)
          start
          exit 0
      stop)
          stop
          exit 0
          stop
          start
          exit 0
          exit 1
esac
- copied modesmixer2 to modesmixertest
- renamed in /xdeco a copy of basestation.sqb to bss.sqb
- in a PC running Win7 and google chrome http://192.168.0.12:8888/ works flawlessly.
HTH
brgds
